Hey guys I need your help in upgrading my system. Before I further go ahead I mention my current system configuration.
AMD FX 8120 BLACK EDITION
ASUS M5A78L-M/USB3
2 TB HDD
ANTEC X1 CABINET
Corsair VS650 650 Watt PSU
GSKILL 8GB(4X2)DDR3 1600MHZ
ASUS GT610 2GB DDR3
Now, I am interested in upgrading my system RAM and GPU. I want my system to run latest games with decent amount of output. :lol:  I will running my game on 1366x768 resolution. Since I have only PCI-e 2.x slots on motherboard I am left only few options as of my knowledge upgrading to PCI-e 3.0 card will not perform as required and I am not able to find any options in PCI-e 2.x. :huh:  Please suggest me with any option either PCI-e 2.x or PCI-e 3.0(if you are sure it will perform well :P ) in around Indian Currency 10000 or $150. :rolleyes:  Even let me know best RAM upgrade along with my current RAM of 8GB(4x2).
Thank everyone in advance... :)
https://linustechtips.com/topic/299046-need-advice-on-system-upgrade/
You can upgrade the GPU first, but don't go crazy because bottleneck or you can upgrade the CPU first then the GPU to get less bottleneck.
Where I hang out: The Garage - Car Enthusiast Club
My cars: 2006 Mazda RX-8 (MT) | 2014 Mazda 6 (AT) | 2009 Honda Jazz (AT)
PC Specs
Indonesia
CPU: i5-4690 | Motherboard: MSI B85-G43 | Memory: Corsair Vengeance 2x4GB | Power Supply: Corsair CX500 | Video Card: MSI GTX 970
Storage: Kingston V300 120GB & WD Blue 1TB | Network Card: ASUS PCE-AC56 | Peripherals: Microsoft Wired 600 & Logitech G29 + Shifter
Australia
CPU: Ryzen 3 2200G | Motherboard: MSI - B450 Tomahawk | Memory: Mushkin - 8GB (1 x 8GB) | Storage: Mushkin 250GB & Western Digital - Caviar Blue 1TB
Video Card: GIGABYTE - RX 580 8GB | Case: Corsair - 100R ATX Mid Tower | Power Supply: Avolv 550W 80+ Gold
Thanks for the information but could you suggest me which graphic card should I buy? As I am looking for CPU upgrade now.
your mobo is just barely enough to support the FX8320 CPU
the VRMs are not build to handle the high wattage draw of the FX8320
you may be better off swapping to Intel CPU and mobos
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
You should go with R9 2xx card or GTX 7xx card, GTX 9xx card can cause bottleneck.
PC Specs
Indonesia
Australia
