What is the difference between these two?
What is the difference between the GIGABYTE GeForce GTX 980 4GB GDDR5 GV-N980G1 GAMING-4GD and GIGABYTE Geforce GTX 980 4GB GDDR5 GV-N980WF3OC-4GD? The only difference I see is a little price difference and the G1 Gaming has a higher clock speed.
Edit: Well I probably should have googled a little bit more before posting I found the differences. I would delete the post but I have no idea how so if a mod sees this you can delete this.
https://linustechtips.com/topic/298317-what-is-the-difference-between-these-two/
The G1 has a backplate and a supposedly higher binned chip that means better overclocking results.
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
Don't buy a gtx 980 :) it really doesn't make any sense for the price. Buy 2 R9 290s, if you live in the US you can get them for 240$ each on newegg and they'll absolutely floor any 980 for cheaper.
sudo chmod -R 000 /*
Did you really just make a topic while answering your own question... Its clocked higher. Jesus christ.
No need to be an asshole.
I personally have the G1 variant of the GTX 970, it's a great card, but if you want to save some money, the regular version will fare well too.
