BF4 Frame Drops
Go to solution Solved by JustCallMeVlad,
Sounds like a cpu bottleneck
So when in some maps (especially 64 players and when flying in helicopters) I get fairly large frame drops.
I play at 1080p with almost maximum settings (SSAO, 2x MSAA and post processing on high).
I get 70-40fps however the fps drops to 24 in certain areas. When the fps drops it remains for about a second and rises back to normal rate.
Is this a sign of a bottleneck?
A8 7600@ 3.8Ghz (Turbo)
GTX 760 2GB OC (1192Mhz Boost)
https://linustechtips.com/topic/298175-bf4-frame-drops/
That's probably the CPU's fault. The A8 is a pretty "meh.." one.
I guess you could avoid the 64 player maps?
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/298175-bf4-frame-drops/#findComment-4047344
I think it could be CPU related. My CPU usage is fairly high when playing BF4.
Intel i7 4790k / MSI Z97M / Hyper 212 Evo / MSI Twin Frozr GTX 770 / 16GB Corsair Vengeance 1600MHz / Fractal Design Arc Mini R2 / Corsair CS750M / Samsung 840 Evo 250gb SSD /  WD Blue 1TB
https://linustechtips.com/topic/298175-bf4-frame-drops/#findComment-4047345
Core I7 5960X / Gigabyte X99 SOC Force / Kingston 16GB DDR4 3000 / EVGA GTX 980 Classified's In Quad SLI / EVGA 1600W G2
Core I7 6700K / Asus Z170 Maximus VIII Hero / Corsair 16GB DDR4 3000 / MSI R9 290X Lightning / EVGA 1600W T2
https://linustechtips.com/topic/298175-bf4-frame-drops/#findComment-4047380
Stupid question, but how do I overclock a non K APU?
theres no K series APU thats intel and yes its your CPU i had the same issue with my 8350 went to a i7 and no more stuttering
l Intel Core i7 4790K @ 4.5Ghz l Asus VII Ranger ROG l MSI GTX 970 @ 1555MHz l
PC PART PICKER
https://linustechtips.com/topic/298175-bf4-frame-drops/#findComment-4047593
