PSU Cable Sleeving (Help!)
As said already, you can get a modular PSU, and then additional sleeved cables, but they are generally quite expensive for a whole kit (120 AUD for Corsair's Gen2 kits).
So, what I advise you look into, are some PSU extensions.
I got a PCCG Tarantula extension kit and they look awesome, and they were but only $40. Granted there is only two PCI-E 2+6 Pin connectors, all the rest should be covered.
I'd pass on manually sleeving the cables, might be cheaper, Idk, but the amount of time it'd take would not be very kind to me.
Hopefully you have some store that does sleeved cable extensions, PCCG is the only place I know of that does them as a distributor at such a low price.
Edit:
So the parts have already been bought right? If you do get the RM650 you'd still be able to use either extensions or a new set.
