Weird Gpu Load and Power
Go to solution Solved by Elbstrand,
I think it's because you can't max out both at same time, just because stress testing graphics also uses some CPU. When you overload the CPU to a point where it can't really communicate with the PCI-E lanes anymore, your graphics power will drop.
I was recently stress testing my GPU with MSI Kombuster and the GPU runs perfectly fine alone. But when I added OCCT or Aida64 alongside Kombuster, the GPU would drop in its usage percent and its power percent (seen through MSI Afterburner). What is the problem with this GPU load and power delivery?
My system was slightly overclocked but I ran everything at stock settings to rule out that factor, but was still getting the problems. The temperatures were also fine.
My system:
CPU: 3570k at stock
GPU: MSI 660 ti power edition at stock
PSU: Seasonic ss-750km3 750w
Motherboard: Gigabyte GA-Z77X-UD5H
Edit: The reason I wanted to stress both was because I thought my GPU was unstable due to some crashes with the driver (314.22) while playing games.
I have also read that people usually only stress CPU/GPU seperately. Is there a problem with stressing both at the same time?
https://linustechtips.com/topic/29741-weird-gpu-load-and-power/
Christopher Kruse | Webdeveloper (Interface & Applications)
i7 3770k (3233C Batch) @ 4.2ghz | Asus P8Z77 WS | Gigabyte 780 Ti OC  | Corsair Vengeance LP 1600 32GB DDR3 | Samsung 850 EVO 500GB +2x Samsung 840 EVO 250GB + Samsung 830 256GB + 4x WD30EFRX, 2x WD30EZRX, 1xWD20EARS | Corsair AX750 + Bitfenix Extensions | Fractal Design Define XL R2 + Xigmatec 3in3 Hotswap Cage | Noctua NH-D15 + Thermal Grizzly Kryonaut, 5x Noctua NF-P14s redux-1500 PWM | Peripherals: Logitech G502 + Corsair K70 RGB + Red 40A-L O-Rings | Sound: Denon AVR 2807 via HDMI + 2x Nubert nuPro A-20 + 1x B&W CC6 Center | SoundMagic E10 | Jabra Speak 410
https://linustechtips.com/topic/29741-weird-gpu-load-and-power/#findComment-379919
3570K at stock shouldn't bottleneck a 660 Ti. Does the same thing occur when playing a game without Vsync?
https://linustechtips.com/topic/29741-weird-gpu-load-and-power/#findComment-380040
