isopropyl alcohol but that might need more than just cleaning.
Best way is to put some soldering flux (non acid) and run a soldering iron over them. The heated flux should clean the corrosion. After that, clean it with isoproyl alcohol
60FPS Microwave
Intel Core i5-4670K | Galax GTX 970 EXOC | ASRock Z97E-ITX/ac | Team Elite 8GB 1600MHz | Gelid Black Edition | Samsung slowdown + WD Blue 1TB x2 | Cooler Master V550 | Corsair K65 + Logitech G100s | MasterCase Pro 3
ok i'll try what you said, thank you :)
Best to use a fine tipped iron to avoid solder bridges. Dont stay too long or you might melt the plastic
60FPS Microwave
