Hey guys, I'm kinda new to pc stuff, and I had a question about fans on graphics cards. Wouldn't it be better for gpus to have their fans firing upwards? Like instead of the fans shooting air over the fins and then the hot air all over the cards and out each edge, wouldn't it be better if they sucked air in the edges and blew the hot air out the fans, down into your case? Then the air would be going down and the fans could eject it out the back somewhere. That just seems more logical to me, but I'm no expert. :p Thanks!
https://linustechtips.com/topic/29697-question-about-gpu-fans/
Even if it was better its way to late to change that now every GPU in the past has been built with a fan on the bottom and they push cool air from the bottom of the case up toward the cpu area so it can be exhausted.
https://linustechtips.com/topic/29697-question-about-gpu-fans/#findComment-379070
That's not the way air works.
Air coming off the fan is being directed in a certain direction.
Air going into a fan is being sucked from just about every direction around the immediate area of the fan. And it will follow the path of least resistance.
A fan blowing on to the card will put more air in contact with the fins than a fan blowing away from the card would. By a lot.
It wouldn't work sadly.
† Christian Member †
For my pertinent links to guides, reviews, and anything similar, go here, and look under the spoiler labeled such. A brief history of Unix and it's relation to OS X by Builder.
https://linustechtips.com/topic/29697-question-about-gpu-fans/#findComment-379078
2 words water cooling
problem solved
But either way the difference wouldn't be too large and the current design works fine
I beat you @joelthezombie15 :)
<p>Wires Suck :angry:
!fY0|_|(4|\|R34[)7#!5PMM37#3(0[)3:1337 70833|\|73R3[)!|\|49!\/34\|/4Y 4|\|[)93741!f3
https://linustechtips.com/topic/29697-question-about-gpu-fans/#findComment-379085
though it seems like a good idea i doubt it would make much difference, its the same idea as the 90 degree motherboard mounting in silverstone cases, it doesnt actually improve temps by much if it does at all but it looks cool :) more direct to your idea though if your using an air cooler that would be blowing 70 degree heat straight into your cpu cooler and hence increase those temps
https://linustechtips.com/topic/29697-question-about-gpu-fans/#findComment-379086
problem solved
I was literally about to click the thread :/
I have a feeling that your idea would open a huge can of worms. there is probably reasons they have to do it this way.
i5 3570 | MSI GD-65 Gaming | OCZ Vertex 60gb ssd | WD Green 1TB HDD | NZXT Phantom | TP-Link Wifi card | H100 | 5850
“I snort instant coffee because it’s easier on my nose than cocaine"
https://linustechtips.com/topic/29697-question-about-gpu-fans/#findComment-379107
That would actually cause higher temperatures. Air would be coming in from the sides of the cards the most so not as much fresh air intake. With the way the fans are currently the air travels over all the fins even in the middle because the fan is exposed and nothing is blocking the air, then gets pushed outwards so there is more heat dissipation. If it pulled the air from the sides instead of the bottom not as much air would be blowing through the middle fins because the pcb would be blocking the air. It can only come in from the sides effectively so only the fins on the edge would get a proper amount of air flowing through them. This would increase temperatures by quite a lot.
        Sager NP9370EM - I7 3630QM - 680m 1045Mhz - 8gb 1600mhz ram - 240gb msata 750gb hdd
https://linustechtips.com/topic/29697-question-about-gpu-fans/#findComment-379121
he is right you are everywhere, not almost everywhere but EVERYWHERE
https://linustechtips.com/topic/29697-question-about-gpu-fans/#findComment-379182
There are times that im not on :p
https://linustechtips.com/topic/29697-question-about-gpu-fans/#findComment-379186
There are times that im not on :P
joelthezombie15 schedule
01:00am-07:00am Linus tech tips forum
07:00am-07:03am food
07:03am-02:30pm Linus tech tips forum
02:30pm-02:33 food
02:33pm-12:00pm Linus tech tips forum
12:00pm-01:00 am sleep
JK  :P
https://linustechtips.com/topic/29697-question-about-gpu-fans/#findComment-379240
02:30pm-02:33 food
JK  :P
You got it all wrong, i eat while on the forum :p
https://linustechtips.com/topic/29697-question-about-gpu-fans/#findComment-379244
multitasking like a boss! lol :P
BTW do you eat while you sleep?
No but i sleep while i eat :?
https://linustechtips.com/topic/29697-question-about-gpu-fans/#findComment-379564
send me a picture i want to know how that looks  :ph34r:
http://media1.arabia.msn.com/medialib/2012/09/21/man-asleep-at-desk-1.jpg
https://linustechtips.com/topic/29697-question-about-gpu-fans/#findComment-379729
i can't believe you sent a picture of a guy snorting coffee while asleep  :lol:
Lol, what? you asked for what it would look like.
https://linustechtips.com/topic/29697-question-about-gpu-fans/#findComment-379741
