I was thinking about buying an FX-4300 and a CM Hyper EVO 212 and was wondering if the 970 chipset would be powerful enough to push the evo 212. These are the boards I was looking at:
970: http://pcpartpicker.com/part/asus-motherboard-m5a97r20
990X: http://pcpartpicker.com/part/asus-motherboard-m5a99xevor20
99FX: http://pcpartpicker.com/part/asus-motherboard-m5a99fxpror20
Athlon X4 760K | MSI A88X-G43 | 8GB G.Skill Ripjaws 1333Mhz | MSI R7 260X 2GB | Corsair 300R | Corsair CX430 | 640GB HDD | Windows 7 64-bit
HP W2071d 20" 900p TN | Stock Dell K/B | Microsoft Comfort Optical Mouse 3000 + SteelSeries Qck Portal 2 Ed. | Grado SR80i + cheap 2.0 speakers
https://linustechtips.com/topic/29641-970990x990fx-for-overclocking/
I can't find the power phases on any of the boards. Generally speaking, 990FX chips tend to have more power phases for better overclocking.
if you're not planing to crossfire go with the 970 board, But take instead the Asus m5a97 EVO, the EVO have more power phases than the "normal" m5a97 board.
But if later you want to Crossfire go with the 990fx board
Edit : Sorry i meant crossfire
I7 4770K - @4.5Ghz  |  Be quiet Dark Rock Pro 3  | Asus Maximus VII Ranger Z97  | Kingston Genesis 8GB | Be quiet Power Zone 750w   | Sapphire R9 Fury X |  Sandisk SSD 120Go + WD Green 1TB 7200 rpm | Nzxt Phantom 410
chipsets dont really matter on their own but a higher end chipset usually has better voltage regulation etc. (better for ocing) but I think some 970 boards like the Gigabyte 970a-UD3 will overclock better than a lower end 990fx board, its rare to see 990x boards in general.
also you wont need an h100i to oc a 4300, ur paying almost as much for the cooler as the cpu if you were to listen to ariceneo itd be better just to buy an 8350 with stock cooling.  the chipset wont make a huge difference in overclocking, so buying any old 990fx board might not guarantee you can oc further than a 970, in terms of performance theres not a huge difference between 970 and 990fx boards except features and pcie lanes/bandwith
Generally, the 990FX chipset allow for better OCing, that's why most have greater success OCing FX CPUs with this chipset. I'm no master OC'ed, far from it actually :( , but my FX8350 is doing 4.5ghz stable with a slight voltage bump from 1.35V to 1.375, this is on my Asus Crosshair V Formula mobo. I'm using RipJawsX 2133mhz RAM, with a CM Hyper 412Slim (swapped the POS dual slim fans for a Corsair 120mm SP Performance fan). I had this mobo when I was running an FX4100, moved on to an FX8120 and to the present FX8350. I've had pretty good OC with all the CPU I ran with this board.
 Main Rig: AMD AM4 R7 5700X3D (8C/16T) + TR Phantom Spirit 120 EVO | Gigabyte X570 Aorus Xtreme | 2x 16GB Kingston Fury Beast DDR4 3600 | XFX MERC 310 RX 7900 XTX | 256GB Sabrent Rocket NVMe M.2 PCIe Gen 3.0 (OS) | 4TB Crucial P310 NVMe M.2 PCIe4x4 | 2TB TG Cardea Zero Z440 NVMe M.2 PCIe Gen4x4 | 4TB Samsung 860 EVO SATA SSD | 2TB Samsung 860 QVO SATA SSD | 6TB WD Black HDD | CoolerMaster H500M | Corsair HX1000 Platinum | Logitech G915 + G303 Shroud Ed + 8BitDo Ultimate 2.4G | iFi Micro iDSD Black Label | Philips Fidelio B97 | C49HG90DME 49" 32:9 144Hz Freesync 2 | Omnidesk Pro 2020 48" | 64bit Win11 Pro 24H2
2nd Rig: AMD AM4 R9 5900X (12C/24T) + TR PA 120 SE | Gigabyte X570S Aorus Elite AX | 2x 16GB Patriot Viper Elite II DDR4 4000MHz | Sapphire Nitro+ RX 6900 XT | 500GB Crucial P2 Plus NVMe M.2 PCIe Gen 4.0 (OS) | 2TB Adata Legend 850 NVMe M.2 PCIe Gen4x4 |  2TB Kingston NV2 NVMe M.2 PCIe Gen4x4 | 4TB Leven JS600 SATA SSD | 2TB Seagate HDD | Logitech G613 + G703 | SOLDAM XR-1 Black Knight | Enermax MAXREVO 1500 | 64bit Win11 Pro 24H2
HTPC: AMD R7 6800H | 32GB DDR5 4800MHz | AMD 680M iGPU | 2TB SSD (2 Partitions 400GB + 1.4TB)) + 1TB SSD | Logitech G613 + G304 | Win11 Pro  24H2
Laptop: Lenovo Legion 5 Pro 16ACH6H - AMD 5800H | 32GB DDR4 3200MHz | 680M iGPU | 1TB Kingston NV1 NVMe M.2 (OS) | 4TB Lexar NM790 SSD | Win11 Pro
Thanks for all the replies, I think I am going with the 990X board becuase it has the same power design as the 990FX. The only difference is the PCIe lanes are much lower speed on the 990X. Since I do not plan to crossfire/SLI, I think I am good.
