Im going to have a Corsair Air 240 and since there is no room on top to put a 38mm radiator there, i need to place it in the front of the case. My question is should i have fans in push/pull pulling cool air in from the outside in or in push/pull from inside out, or in pull only from outside in, etc. you get the idea :) lol. Thanks
https://linustechtips.com/topic/295659-radiator-fan-orientation/
It's better to go pull, because it will be easier to clean.
Check out this thread.
https://linustechtips.com/topic/295659-radiator-fan-orientation/#findComment-4014323
