Im looking for a PSU because i am planning on upgrading my GPU or just getting another one. So i will need to help a higher voltage PSU my current PSU is 430W from corsair I would like to know a safe Watage i could buy and a good seller as well. Also plan on doing some over clocking if that affects anything.
Specs:
Motherboard:: ASUS Z97-A                  Ram:: G.SKILL Ripjaws X Series 8GB (2 x 4GB)              SSD:: Intel 730 series 240Gb SSD
GPU:: ASUS Radeon R9 270(x1)                  CPU:: i5-4690K CPU @ 3.50                   PSU: CX430                 Fans: (4x) Rosewill SFC LED cooling fan blue
CPU cooler: CM 212 EVO
Motherboard:: Asus Maxiumus ROG Crosshair VII AM4     Ram:: G.SKILL TridentZ RGB Series 16GB (2 x 8GB)     SSD:: Intel 730 series 240Gb SSD
 GPU:: ASUS GTX 1080 8GB ROG Strix     CPU:: AMD Ryzen 7 2700x @3.70GHz   COOLING:: NZXT Kraken x72 AiO, 3x Thermaltake Riing Plus
https://linustechtips.com/topic/295585-going-to-add-another-gpu-psu-help/
How much of a budget are you willing to spend on a new Power Supply?
At most 100USD
