All H97 boards don't support SLI due to PCI-E speed, but mid-to-high end Z97 boards do
Scarlet KnightIntel Core i3 6100 || Antec A40 Pro CPU Cooler || MSI Z170A Gaming M5 || Kingston HyperX 16GB DDR4-2133MHz || Samsung 850 Evo 120GB || Seagate Barracuda 1TB || Gigabyte G1 Gaming R9 390X 8GB || Seasonic M12II 620W || In Win 503 || Corsair Strafe || Steelseries Kinzu V3 MSI Edition || Dell UltraSharp U2414H || Xiaomi Alumunium Mouse Pad (S)
#Gadget:
Phone: BlackBerry Classic Q20, Samsung Galaxy Note 4 S-LTE SM-N916S
Console: PlayStation 4 500GB CUH-1206A
Tablet: iPad Air 2 16GB Wi-fi Only
Laptop: MSI GE62 (i7 4720HQ || 8GB DDR3 || NVIDIA GTX960M || Samsung 650 EVO 120GB + 1TB HDD)
In-ear Monitor: Xiaomi Piston 3.0
Alright so if I'm building a server with a super low end GPU I should stick to H97?
Are you going to use the Xeon E3? If yes then go with B85, they are considerably cheaper than H97 (except gaming B85 mobo)
#Gadget:
Yeah I am. So basically when I'm checking for a MOBO for my CPU all that really matters is the socket, and not the actual chipset for contability. The chipset will only support more features like SLI, overcloocking?
Yep, pretty much. Some will have newer storage solutions, but nothing that's particularly practical for a sever.
I suppose you used a E3 Xeon?
Yes, here's more info if you need
E3 = Socket 1150
E5v2 and E7v2 = 2011
E5v3= 2011-3
#Gadget:
I will also add something to this.
A Xeon E3-1230V3 will work on a B85 board out of the box. Since this is basicly a haswell 1.0 chip.
A Xeon E3-1231V3 (so everything with a 1 at the end), will "probably" not work out of the box on a B85 board.
Because these cpu´s are basicly haswell 2.0 chips. So those boards need a bios update to support these cpu´s.
I would personaly recommend a Xeon 1231-V3 with a H97 board.
Haswell refresh cpu´s  or haswell 2.0 like i wanne call them, dont work out of the box with most 8 series boards.
They all need a bios update in most situations.
Just buy newly released B85, they will all come with latest BIOS version that supports Haswell Refresh
Hell, when i bought my B85, it already has overclocking options, its update log has hinted future support for HR as well
#Gadget:
Yes, a Xeon 1225 v3 to be exact. Any of the Xeon E3 series should work fine with normal desktop chipsets like Z97, H97 and B85. Also if the end of the Xeon model number ends with a 5 (for example Xeon 1225) it means it has integrated graphics. If it doesn't end in a 5 (for example Xeon 1230) then it doesn't have integrated graphics and you will need a graphics card.
Well, how do you know that you exaly buy a newly released B85 board?
Or how do you know, that the exaly board thats sended to you, has had a bios update in the factory?
You never know this. So its just a gamble.
re-sellers, can send you a board, that they had in stock for more then a year.
And at that point you will basicly get stuck, with a mobo + cpu combination that not works out of the box.
As far as i know, new 8 serie boards, are not made anymore.
So why would you take the risk if you are going with a haswell refresh chip?
Because a H97 board will work guaranteed!
Yeah going with the Xeon 1231 V3 with this board and a cheapo 30-50$ GPU.
http://www.canadacomputers.com/product_info.php?cPath=1201&item_id=071445
