hi I'm running an i7-4770k with an H80i on an ROG Maximus vi board,
I've had this set up for about a month, and wanted to overclock, i stressed my cpu prior to overclocking using prime 95, and my temps while under load are around 95C
im pretty sure somethings wrong with my watercooler but i need a second opinion
https://linustechtips.com/topic/294989-cpu-too-hot/
What's you OC speed. Plus with H80i that sounds about right, it's not that great of a cooler.
My Rig:  CPU: Core i7 4790K @4.8ghz  Motherboard: Asus Maximus Vii Hero  Ram: 4x4GB Corsair Vengeance Pro 2400mhz (Red)  Cooling: Corsair H105, 2x Corsair SP120 High Preformance Editions, Corsair AF 140 Quiet Edition  PSU: Corsair RM 850  GPU: EVGA GTX 980 SC ACX 2.0  Storage: Samsung 840 EVO 120GB, WD Blue 1TB  Case Corsair 760t (Black)  Keyboard: Razer Blackwidow Chroma  Mouse: Razer Deathadder Chroma  Headset: ATH-M50X Mic: Blue Yeti Blackout
https://linustechtips.com/topic/294989-cpu-too-hot/#findComment-4004824
Please don't use prime 95. Prime 95 stresses the CPU more than it should, it may harm the CPU itself.
Use the Intel burn test.
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
https://linustechtips.com/topic/294989-cpu-too-hot/#findComment-4004828
wow didnt even know that my current cpu speed http://gyazo.com/1dd16dd80cd8b7603f6c41844c82e3be
3.5GHZ?
https://linustechtips.com/topic/294989-cpu-too-hot/#findComment-4004850
And here im sitting with my 4790K at 4.8ghz at 55C 100% load.
https://linustechtips.com/topic/294989-cpu-too-hot/#findComment-4004858
