Welcome to the forums :)
Whats your location and what do you intend using it for?
EDIT; just noticed it's in the pc gaming forum section, so i guess i see what you want to use it for.
As friendly advice, next time post it in the "new builds and planning" section, more people may see it :)
Bleigh!  Ever hear of AC series?
https://linustechtips.com/topic/294674-building-pc/#findComment-4000686
Hey can you guys help me build a pc with budget 800 dollars?
This probably should've been posted in the following section.
http://linustechtips.com/main/forum/18-new-builds-and-planning/
ON A 7 MONTH BREAK FROM THESE LTT FORUMS. WILL BE BACK ON NOVEMBER 5th.
Advisor in the 'Displays' Sub-forum | Sony Vegas Pro Enthusiast & Advisor
  Tech Tips Christian Fellowship Founder & Coordinator
https://linustechtips.com/topic/294674-building-pc/#findComment-4000725
https://linustechtips.com/topic/294674-building-pc/#findComment-4000890
Intel Build with GTX 970
CPU: Intel Core i3-4360 3.7GHz Dual-Core Processor  ($141.99 @ SuperBiiz)
Motherboard: ASRock H97 Anniversary ATX LGA1150 Motherboard  ($71.99 @ SuperBiiz)
Memory: Kingston Fury Series 8GB (2 x 4GB) DDR3-1600 Memory  ($66.98 @ OutletPC)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($49.88 @ OutletPC)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE Video Card  ($359.99 @ Amazon)
Case: Corsair 200R ATX Mid Tower Case  ($57.99 @ Micro Center)
Power Supply: EVGA SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($59.99 @ Newegg)
Total: $808.81
Generated by PCPartPicker 2015-01-20 11:58 EST-0500
If you can go 100$ more:
Buy SSD: Crucial MX100 128GB 60$
Buy CPU Cooler: CM Hyper 212 Evo 30$
"I am like ninja, but less gay" - Deadpool
https://linustechtips.com/topic/294674-building-pc/#findComment-4001234
Total: $808.81
I like this build, but core i3 is not too bad? I mean i don't know a lot about fps or smth, but i think i will need better processor than i3.
Ty for answer, but i dont like amd's.
Im new at this forum, didn't know.
https://linustechtips.com/topic/294674-building-pc/#findComment-4002283
if u want get gtx 770 since it is in a budget if u want cpu get i3 or i5 4460 but get bad gpu fore games
https://linustechtips.com/topic/294674-building-pc/#findComment-4002316
