Swiftech H220x with stock or aftermarket fans?
Solved by VSG,
I wouldn't really bother with the NF-F12 since the performance would be a dip as well, along with noise. What you need are fans that provide the same, if not better airflow through the MCR220QP style radiator in there, at lower noise. Look at something like the EK Vardar F3/F4 fans, or possibly the NB eLoop B12-3/4. If you are open to eBay/server retailers, then look also at 2000 RPM 3/4-pin fans from Delta and Sanyo Denki.
Alternatively, you can run the stock fans and pump at 60-75% PWM signal and call it a day.
