I'm planning on building a new system but the most difficult decision to be made seems to be the case. I have always been in loved with the 750D and it appeared to be the perfect chasis. But I just read it has serious airflow problems because of the restricted front intake. Is that true 750D owners? Should I buy the 760t then?
Thanks in advance!
https://linustechtips.com/topic/293847-750d-airflow-problems/
its not restricted, it has enough airflow
you can also add more fans to the bottom for even more
https://linustechtips.com/topic/293847-750d-airflow-problems/#findComment-3989473
Corsair is currently developing a new front panel based on the 450D's.  If you don't need the case immediately it should hopefully be ready in a couple of months. You can track the progress here:
http://forum.corsair.com/v3/showthread.php?t=123028&page=18
CPU Intel Core i7 7700K; Cooler Cryorig R1 Universal; MB Asus ROG Maximus IX Code; RAM G.Skill Trident Z 3200Mhz (4 x 8GB); GPU ASUS GTX 1080 Ti ROG Strix Gaming OC; Case Be Quiet Dark Base 900 Pro Silver; Storage Samsung 960 EVO 500GB, Samsung 850 EVO 1TB, Seagate Barracuda 4TB; PSU EVGA Supernova 850W G2; OS Windows 10; KB Corsair K70 (MX Brown); Audio O2 & ODAC, Sennheiser HD 600, Sennheiser RS 185, Swan M200MKIII; Monitors 2x Dell U2410
Previous Build
CPU Intel Core i5 4690K; Cooler Cooler Master Hyper 212X; MB Asus Z97-A; RAM G.Skill Sniper (2 x 4GB); GPU 2x Gigabyte GeForce GTX 970 G1 Gaming (SLI); Case Corsair Obsidian 450D; Storage Samsung 840 EVO 120GB, WD Black 1TB, Hitachi 750GB; PSU EVGA Supernova 750W G2; OS Windows 10;
https://linustechtips.com/topic/293847-750d-airflow-problems/#findComment-3989527
I have a 750D, personally the air flow isn't that great. It's a bit restictive but I somehow STILL have dust all over inside my case. I'm planning on getting an Air 540 or a H440 to replace it.
NCASE M1 i5-12600kf  RTX 4060Ti FE Z690M-ITX  SF600 NH-L9x65 Chromax  LPX 32GB
https://linustechtips.com/topic/293847-750d-airflow-problems/#findComment-3989549
Everybody seems to have different opinions about this case... it is good even if im plannig to stick a couple of gtx 970 in there? (Open cooler design) I really love the looks of the case, but I also want something functional. Does Linus ever comment here?
https://linustechtips.com/topic/293847-750d-airflow-problems/#findComment-3992781
It's not a good care.
Bad air flow, bad build quality, high price, overused.
https://linustechtips.com/topic/293847-750d-airflow-problems/#findComment-3993014
If you're really set on the case I wouldn't be too concerned by putting two 970s in there.  Those cards run pretty cool.  I've never seen my card (Gigabyte G1) go over 72C under max load with my case fans set at really low RPM.  @ThatCoolBlueKidd might be able to provide a better answer as to how cards perform in the case.  That being said, the 760T does offer better airflow although it sure doesn't look as sleek as the 750D.   If you're still concerned about the airflow and still want an Obsidian, the 450D is a good option - more than ample airflow and maxing out on case fans means you can run them all real quiet. (LED fans look real good behind the front panel too.)  Only thing I don't like about it is that it could use some more cable management loops and there's no routing hole for front panel audio.  So pretty much what Linus said in his vid review.  You'd need to ditch HDDs or mount them in the 5.25 bay if you're using two tri-fan cooler 970s (eg. Gigabyte, Zotac) though - there isn't enough room for the second one with the cage there.
EDIT: It is actually possible to use the drive cage and SLI two Gigabyte Windforce cooler cards.  Was fiddling with my ODD stealth cover and decided to check the clearance when hanging the drive cage from the ODD bays.  There's about 1-2mm clearance between the backplate and the cage.  I wouldn't recommend it, but it is possible.  It would also open up another 120mm fan slot.
Previous Build
https://linustechtips.com/topic/293847-750d-airflow-problems/#findComment-3995916
THIS.
As I said, I'm ditching my 750D for an Air 540 asap, I'm not to wow'd by the case as in my opinion, it was slightly overhyped - and not 'corsair quality' in my opinion. At about 10C ambient my 980 reaches 50C easily, 35C with the front cover off though (under light-medium load). The 'brushed aluminium' front panel is really just a glued piece of metal on a piece of plastic, of which my clips broke almost instantly, it's impossible to clean, and the glue is coming undone less than a year into being owned. Airflow certainly isn't good, heck the H440 probably has better air flow.
https://linustechtips.com/topic/293847-750d-airflow-problems/#findComment-3997154
air flow on that case isn't that great at all trust me, thats why I went with 760T, absolutely no regrets what so ever. the 760T and 780T are great, depending what you like, personally I like the 760T more coz its more open, internal is exactly the same.
Also you might want to consider the air 540, that case has one of the best cooling ever, the air blow directly on to the hot parts of the pc
https://linustechtips.com/topic/293847-750d-airflow-problems/#findComment-3997707
Thanks for the anser! But if what you say is true, it means that cases like the H440, the 350D and the Define R4 have the same front intake problems?
https://linustechtips.com/topic/293847-750d-airflow-problems/#findComment-4004330
in a sort of way they all do.
as with the 900D, 750D, 350D all have the front panel (with side reliefs) plus a
fine mesh filter. the H440 has a larger (by volume) openings along the one side
to allow more airflow. the R4 has serrated openings (still more than the Corsair)
as well as a moderate filter mesh. but to all those, they are "hush" cases (muffles
the intake fan noise) at the cost of internal performance. an open style front
intake can be as quiet (depending on fan(s) selected) as a door chassis.
most are minimal restrictions, unless haredcore on lowest temps needed.
https://linustechtips.com/topic/293847-750d-airflow-problems/#findComment-4005128
Thank you! So in conclusion if I'm planning to stick two gtx 970 with open cooler design (asus strix) and an overclocked i5 cooled with a H100i, the 750D will be okay or not?
https://linustechtips.com/topic/293847-750d-airflow-problems/#findComment-4014512
THIS.
Thank both for the answer! Seems to be that the 750D isn't as good option than I though it was, I just want a smooth looking case that is also very functional and has good airflow, now im looking at the air 540 or the 760t (more this case because of the huge window) I'll keep searching other options, thanks!
https://linustechtips.com/topic/293847-750d-airflow-problems/#findComment-4014563
the 750D will be ok, a bit overkill, but ok.
one chassis to look at would be the phanteks enthoo pro. tad bit smaller, deffo
less expensive, open front grille, and very open case. fan-wise, they don't sell
many fans with it (know peeps like other fans)
https://linustechtips.com/topic/293847-750d-airflow-problems/#findComment-4014567
Yeah, I read it is an incredible case, but I'm not amazed with the looks of it... considering it on my list, though.
https://linustechtips.com/topic/293847-750d-airflow-problems/#findComment-4014603
It's a very beautiful case,but with bad airflow.
I'm still waiting for the new front cover from corsair.
Especially in the summer, I have serious problems with high temps.
I'm thinking about to buy a new one, but i don't have the money right now.
Maybe in the summer.
Intel I9 7900X , Gigabyte X299 Aorus gaming 9, Gibabyte Geforce GTX 1070 8GB G1 Gaming ,G Skill ripjawsV 32GB 3200 MHZ, Samsung 850 Evo 500GB ,External WD 640GB, 2 x WD 1 TB Blue, Evga Supernova 750 G2, Logitech Z5500, Gigabyte Aivia Osmium, Logitech G502 Proteus Core, Corsair 750D Full Tower, Corsair H110, Asus VS248H 24", Asus VG245HE 24".
https://linustechtips.com/topic/293847-750d-airflow-problems/#findComment-4015645
you're completely wrong....
It seems impossible until it's done.
https://linustechtips.com/topic/293847-750d-airflow-problems/#findComment-4018225
