Hey guys,
i have an old (roughly 5 years) pre-built computer from an Australian brand (Pryon)
over the past 2 years i have replaced the PSU (was ripped off have way more power than any build should need), added an extra fan and upped the GPU to a GTX 760. The time has come for me to upgrade the MOBO (currently and old Foxconn) and CPU (an early i5)
Thats where you guys come in.
I think i have settled on the AMD FX 6300 and was looking for a MOBO to support the rest of my Franken-build (has to be compatible with my RAM
my parts -
http://pcpartpicker.com/p/VJsMD3
http://www.gskill.com/en/product/f3-12800cl9d-8gbxl
notes -
i have no overclocking experience but would be open to trying it
fairly tight budget
first time replacing parts myself
Planning on wiping my HDD
Cheers, Trusty
ps is there any issue transferring from intel to AMD
https://linustechtips.com/topic/293354-need-help-finding-a-budget-mobo/
There is no issue from transfering to Intel from AMD (or the other way round), apart from the price premium.
And at this point you've basically completely rebuilt the PC. In MOST circumstances I'd recommend a G3258 and any H97 motherboard. Would probably be just fine with the GTX760 and gives you a platform to build off of in the Intel Motherboards in a later iteration. AMD haven't updated their FX chips in a while, they're approaching outdated-ness.
NCASE M1 i5-12600kf  RTX 4060Ti FE Z690M-ITX  SF600 NH-L9x65 Chromax  LPX 32GB
I personally can't recommend AM3+ processors anymore. If you want a budget AMD pc, get a APU or 860K. Or a i3 + H81 board
Remember a wise man once said, "You'll most likely hear/see more bad reviews from products than good, because if they get a good product, they won't bother to write a review, and if they got a bad product, they'll complain about the product" ~ SoftenButterCream
if the AMD FX 6300 is a bad choice can anyone suggest an alternative roughly same price range
It's not a bad choice. I have the 6100 sitting in my computer right now and it runs wonderfully.
Intel i3 or 860k
id go with anthlon 4k 860k if ur dead set on that budget. get a 212 evo overclock it to 4.5 and be a happy camper. id never go duo core unless ur just web browsing or doing micro things, games do use 4 cores now and duo cores do the job but not nearly as well.
I3 has hyper threading and it still gets the job done gaming.
i can probs push it to $320ish AUD
i3 + h81 board
CPU: Intel Core i3-4130 3.4GHz Dual-Core Processor  ($99.00 @ Storm Computers)
Motherboard: ASRock H81M-DGS Micro ATX LGA1150 Motherboard  ($39.00 @ Centre Com)
Total: $138.00
Generated by PCPartPicker 2015-01-19 03:24 EST+1100
huilun02, on 18 Jan 2015 - 08:24 AM, said:
Just the graphics card and memory alone costs $300
And your total budget is $320?
I think its for mobo + cpu. But if total is 300... I don't even know what to recommend
i have the GPU and Memory already im spending that to get the CPU
Total: $138.00
Generated by PCPartPicker 2015-01-19 03:29 EST+1100
Edit: Making a i5 build
would you recommend the i3-4130 over the i5-4460
You can afford a i5 so, i'd recommend getting a i5. Heres a CPU+Mobo
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($237.00 @ Centre Com)
Motherboard: MSI B85M-P33 V2 Micro ATX LGA1150 Motherboard  ($69.00 @ Centre Com)
Total: $306.00
Generated by PCPartPicker 2015-01-19 03:31 EST+1100
Another one
Motherboard: Asus H81M-E Micro ATX LGA1150 Motherboard  ($60.00 @ Centre Com)
Total: $297.00
Generated by PCPartPicker 2015-01-19 03:34 EST+1100 Cheaper as well
