Hello all,
I have a GTX 550 Ti, a terrible card actually, I'll be upgrading as soon as the GTX 960 releases. A few weeks ago I was able to play BF4 everything low on a stable 60 FPS.
I completely reinstalled windows 7 about 2 weeks ago because I thought I had a virus.
Since then, my FPS is actually terrible. It's jumping between 30-60, extremely laggy. This started all when I did a clean install of windows. I run at 1920x1080.
I have an i7 860 @ 2.80GHz and 6GB RAM. I have the latest drivers, also tried a clean install of them with Display Driver Uninstaller.
I don't really get how this is possible, since I had good FPS before the reinstall.
I'll be upgrading soon, but I still want to know how this is possible.
Thanks
https://linustechtips.com/topic/293324-very-low-fps-on-bf4/
Hello all,
Thanks
why are you waiting for a 960, 980s are only like 400 pounds now
My Personal PC 'Apex' https://uk.pcpartpicker.com/user/LiamBetts123/saved/3rTNnQ
Intel Core i9 9900k, ASUS Z390-A, RTX 2080TI, Meshify C, HX 850i, 32GB Gskill Trident Z RGB @ 3200MHZ, 500GB NVME, 500GB SSD & 2 x 4TB Baracudas
1
https://linustechtips.com/topic/293324-very-low-fps-on-bf4/#findComment-3982790
try downloading older Nvidia drivers, as far back as end of 2013. some 400-500 series Nvidia cards have the worst driver experience (in my experience).
http://www.nvidia.com/object/win8-win7-winvista-64bit-314.22-whql-driver.html this one should work better (i hope)
R9 3900XT | Tomahawk B550 | Ventus OC RTX 3090 | Photon 1050W | 32GB DDR4 | TUF GT501 Case | Vizio 4K 50'' HDR
https://linustechtips.com/topic/293324-very-low-fps-on-bf4/#findComment-3982807
Well the thing is, BF4 won't run on that driver. It gives me an error, then I just can't open the BF4 application anymore.
It says I need at least version 331.
Also, I don't want to buy a 980 due to its high price IMO.
Edit: it worked suddenly. It's better now, but my FPS is still jumping between 45 and 60, still way too laggy to play decent.
https://linustechtips.com/topic/293324-very-low-fps-on-bf4/#findComment-3983318
