You should get 2 memory modules ( and a better PSU )
Done RAM advice on PSU, want modular as changed to a build i've seen that uses mini itx
This is my new build:-
ttp://uk.pcpartpicker.com/p/ZPjvYJ
Only confused aswel between
Node 304
http://www.scan.co.uk/products/fractal-design-node-304-black-mini-itx-case-with-usb-30-w-o-psu-(std-atx)
Or
Cooler master 915F
http://www.scan.co.uk/products/cooler-master-haf-stacker-915f-midnight-black-mini-itx-case-expandable-stackable-computer-chassis-fr
https://linustechtips.com/topic/293241-water-cooling-case/#findComment-3982678
