Hard Drive Connection
Go to solution Solved by DigitalHermit,
So what it does is change the SATA connection into something else? Is it a converter?
It plugs in to your PCIe slot to provide additional SATA ports...
Plug everything into your mobo and enough of these and your 18-drive array should work...
Unless you're doing a RAID array, this will be fine...
I suppose you'll be getting a sufficient PSU and enough molex to SATA adapters to power this array so you should be golden....
I need to connect 18 hard drives to my motherboard, because of the ridiculous amount, I'm pretty sure I'm going to need some kind of special cable or cables. Any idea what I need?
a raid card perhaps?
you can get this mobo:
http://www.tomshardware.com/news/asrock-x99-extreme11-sata,27854.html
Are you new to the forums???? read the Code of Conduct HERE WANT SOME AWESOME LTT THEMED WALLPAPERS??? check out XTanksSlayerX's wallpaper thread HERE
"May our framerates be high, and our temperatures low" - PC MasterRace
https://linustechtips.com/topic/292988-hard-drive-connection/#findComment-3978380
Will you be able to power all of these drives?
Sig under construction.
https://linustechtips.com/topic/292988-hard-drive-connection/#findComment-3978394
Can I ask why you need to connect 18 hard drives. If I know why, I could maybe suggest a suitable solution.
https://linustechtips.com/topic/292988-hard-drive-connection/#findComment-3978438
Judging by the OPs lack of details, and ridiculous request, this seems like either a troll, or something really stupid, or something 90% of this forum will frown upon.
G3258 V 860k (Spoiler: G3258 wins)
i7-4790K | MSI R9 390x | Cryorig H5 | MSI Z97 Gaming 7 Motherboard | G.Skill Sniper 8gbx2 1600mhz DDR3 | Corsair 300R | WD Green 2TB 2.5" 5400RPM drive | <p>Corsair RM750 | Logitech G602 | Corsair K95 RGB | Logitech Z313
https://linustechtips.com/topic/292988-hard-drive-connection/#findComment-3978884
May I ask what it is for?
He's already shot others down when they asked, and this is his second post today concerning these drives. My view of this whole thing is quite negative. Should be funny though once we finally find out what is up with this ridiculous request.
https://linustechtips.com/topic/292988-hard-drive-connection/#findComment-3978904
http://linustechtips.com/main/topic/292788-specific-motherboard/#entry3978350
This is his other topic, BTW.
https://linustechtips.com/topic/292988-hard-drive-connection/#findComment-3978918
https://linustechtips.com/topic/292988-hard-drive-connection/#findComment-3978994
It plugs into our motherboaed and gives you more data connectors! WHAT DO YIU NEED 18 DRIVES FOR, TELL US!
https://linustechtips.com/topic/292988-hard-drive-connection/#findComment-3979004
https://linustechtips.com/topic/292988-hard-drive-connection/#findComment-3979009
I'm not trolling, I'm serious.
Then prove it by telling us what you need this for.
https://linustechtips.com/topic/292988-hard-drive-connection/#findComment-3979032
Storage, and operating system testing. It's a long story.
Explain more. That still sounds super-sketchy.
https://linustechtips.com/topic/292988-hard-drive-connection/#findComment-3979042
