Have you tried using the keyboard arrows to change the settings?
I'm going to put a link to my PC specs which actually aren't my PC specs and I cry myself to sleep everyday so I can have these PC specs but I can't afford these PC specs so PC specs PC specs PC specs PC specs PC specs PC specs.
https://linustechtips.com/topic/292280-gta-iv-help-solved/#findComment-3969949
using a 7950 or a 7970 right?
Ill find the fix real quick
Edit: Didn't see your build at first. Anyway it happens when your gpu has 3 or more GB of VRAM.
"i had this same problem
right click on GTA4, select properties, then select launch options
copy and paste this into the field that comes up
-nomemrestrict -norestrictions
exactly like that,
the reason why its not letting you set anything is because gta4 only supported GPUS up to 2gb, so since yours is 3gb, it miscalculated how much ram was up for use and thinks you dont have enough, therefore enforcing this lock down on the graphics options,
that command line will bypass it"
http://forums.steampowered.com/forums/showthread.php?t=2821173
https://linustechtips.com/topic/292280-gta-iv-help-solved/#findComment-3969975
exactly like that,
thank you that worked just got to get lcpdrf mod in the game now wish me luck  :)
https://linustechtips.com/topic/292280-gta-iv-help-solved/#findComment-3970042
