We need the rest of your build as well. This is far from enough info
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/292228-problems-with-fps/#findComment-3969190
Please post the rest of your specs.
https://linustechtips.com/topic/292228-problems-with-fps/#findComment-3969192
Vsync is off
You have it locked at 30fps
What slot is your card in?
[-] i7 4790k @ 4.7ghz [-] Asus Maximus VII Formula [-] EVGA Gtx 980 Sc [-] Corsair H105 [-] Corsair Obsidian 750d [-]
https://pcpartpicker.com/user/TBNRunity/saved/#savedbuild_1797964
https://linustechtips.com/topic/292228-problems-with-fps/#findComment-3969204
What info do u need? Tell me and I'll write them down
Everything that matter,s CPU, RAM, Motherboard and preferibly what storage device you use.
My Gaming PC
|| CPU: Intel i5 4690@4.3Ghz || GPU: Dual ASUS gtx 1080 Strix. || RAM: 16gb (4x4gb) Kingston HyperX Genesis 1600Mhz. || Motherboard: MSI Z97S Krait edition. || OS: Win10 Pro
________________________________________________________________
Trust me, Im an Engineer
https://linustechtips.com/topic/292228-problems-with-fps/#findComment-3969280
