DisplayPort help
Go to solution Solved by Ssoele,
That's a mini displayport to a normal one.
Then how about this one? https://tweakers.net/pricewatch/331458/delock-displayport-male-naar-displayport-male.html
Hi guys, I have a little problem.
I'm going to buy a 144 Hz monitor and need a displayport cable. The problem is that I can't find any cable with a reasonable price. They are either really expensive or a displayport to any other connector cable. I just need a displayport to displayport.
I live in the Netherlands so I'd prefer a Dutch site where I can buy one, but a international/foreign site with low shipping costs is no problem either. I hope someone can help me find a good cable.
Thanks in advance ;)
Mah Build:  CPU: Intel i7-7700K COOLING: NZXT Kraken X52 GPU: Asus Strix GTX 1080 MOBO: Asus Strix Z270F RAM: 16GB GSKILL TridentZ RGB 3000
CASE: In Win 303 STORAGE: Samsung 850 EVO 250GB, Seagate 1TB  SSHD PSU: EVGA Supernova G2 750W
https://linustechtips.com/topic/291951-displayport-help/
https://linustechtips.com/topic/291951-displayport-help/#findComment-3965810
https://linustechtips.com/topic/291951-displayport-help/#findComment-3965879
Thanks for your help. I already found out that my new monitor comes with a displayport cable in the box, so I was worried for nothing ;)
https://linustechtips.com/topic/291951-displayport-help/#findComment-3966880
