phobya led
Solved by W-L,
How would I do the wiring and stuff? Is there a video or website you know that shows you how to do it? Thanks,
It's fairly simple process but since it will just need a 12V power source from something like a molex connector, but for the strips I recommend SMD 5050 strips since they are a bit larger and very bright for their density. If you want a multi-color setup you will want an RGB kit that has a controller but if you want a single color like white, red, blue and others you can directly connect them to a 12V molex power.
Here's an example of wiring with a few methods:
