Do you want us to list the problems that WE'VE HAD or do YOU HAVE PROBLEMS while gaming and need US TO RESOLVE IT?
If it's the former, I've had one problem where after updating my drivers and optimizing games in GFE, none of my games would start-up and it took a reboot to fix it
Follow the topics you create using the "Follow" button in the top right corner!
One day I will have my GTX 970. One day. PC specs are at my profile.
Not sure how to check what part works with what? Check out my compatibility guide!
https://linustechtips.com/topic/291269-problems-while-gaming/#findComment-3955314
My PC config is
Amd 8150
Gigabyte 970a ds3
Corsair vengeance 8gb 1600 MHz (2x4gb)
HIS R9 270X ICEQ2
corsair cx500
Kingston 64gb sad
Hitachi 1tb HDD
Corsair carbide 400r
And I am facing a problem I.e after I bought r9 270x
While gaming after 10 mins my video output shuts down but my CPU is working I.e all the fans are moving and there is power but no output in monitor ... Happens only while gaming .. So can any one plzz tell what might be wrong
https://linustechtips.com/topic/291269-problems-while-gaming/#findComment-3955321
Fgtfv567 sir I started this thread to get solution for my problem originally but I would be glad to see what problems other people have as it will help all of us learn how to troubleshoot them
First, use the quote button in order to get my attention, and the edit button to change your post. Second, I wasn't clear if you had a problem or were starting a thread to have a discussion.
Third, I would update all of your drivers to make sure it's fine. If you still have the problem, get a different GPU and see if your card needs to be RMA'd
https://linustechtips.com/topic/291269-problems-while-gaming/#findComment-3955335
There is no change even after updating drivers .. And when I changed the GPU it had a hard time recognizing it .. I.e took time to boot and when it did everything went black after logging in
Do a stress test, and see if your PC is stable WITHOUT ANY OVERCLOCKS
https://linustechtips.com/topic/291269-problems-while-gaming/#findComment-3955355
My PC config is
Amd 8150
Gigabyte 970a ds3
HIS R9 270X ICEQ2
corsair cx500
Kingston 64gb sad
Hitachi 1tb HDD
You couldn't put this in your original post? Seriously?
Stress test your system.
https://linustechtips.com/topic/291269-problems-while-gaming/#findComment-3955369
Hi
I ran a burnln video test for GPU along side started gpuz and while on 100℅ use in 12v column there was voltage drop like -4 volts etc.. Not continous but random even for a second and also in vddc and in vddc current and in too the same kinda drop ... Does it mean that my 6 pin connectors are not providing continuous power to my card??
https://linustechtips.com/topic/291269-problems-while-gaming/#findComment-3963589
