Hey guys, so i just scheduled my appointment to take my final driving lesson and then the next week i will take my driving test behind the wheel. When i go to the DMV, do i take the written test and then do the behind the wheel test at the same time? or how does that work, sorry if its a stupid question, i just couldn't get any verification online. Thanks:)
 CPU: AMD FX-6300     COOLER: Hyper 212 EVO    MOBO: ASUS M5A97 R2.0    RAM: Team Vulcan 8Gb (4Gb x 2) , G-Skill Sniper (4Gb x 2)    PSU: Rosewill HIVE-750w    GPU: ASUS HD 7790 2Gb OC    CASE: NZXT Phantom 410    STORAGE: WD Black 1Tb , Intel 530 120Gb     AUDIO: HyperX Cloud , Sennheiser HD 518 , Audio Technica ATH-M30 , Sennheiser MM30G , Yamaha RX-V361 , Pioneer SP-BS22     PHONE: Samsung Galaxy S7 Edge     PERIPHERALS: Razer BlackWidow Ultimate Classic , Logitech g502 ( Thanks Syntaxvgm <3 )
https://linustechtips.com/topic/291089-any-dmv-help/
Are you in america?
yes
https://linustechtips.com/topic/291089-any-dmv-help/#findComment-3953057
I live in USA. When I took my test, it was just the driving portion. I took the written portion to get my permit.
https://linustechtips.com/topic/291089-any-dmv-help/#findComment-3953062
in canada, you take a written test, then scheduel another date to take the driving test (actual driving one)
at least in Québec.
nvm, then
https://linustechtips.com/topic/291089-any-dmv-help/#findComment-3953063
Ah I see. I probably can't help you because I'm Canadian, but up here you take the written test for your G1 (learner's permit) and then it's just a road test for your G2 (sort of full license)
you don't have to take a second written (computer) test befor the driving one in ontario ? well. thats just a bunch of bull
https://linustechtips.com/topic/291089-any-dmv-help/#findComment-3953074
Hi Tie, when I took my driving test in Colorado I had to take a written test(it was very short with simple questions) and a driven test. They were both on the same day and at the same time, so I only had to schedule once. It could be different where you live.
https://linustechtips.com/topic/291089-any-dmv-help/#findComment-3953328
