Viewing angle. Not clear.
Go to solution Solved by ZetZet,
That is TN viewing angle and it's fairly low. Viewing angles define angles at which you can look at a monitor.
Pretty bad TN panel here:
Pretty good IPS panel here:
https://linustechtips.com/topic/290746-viewing-angle-not-clear/#findComment-3947749
https://linustechtips.com/topic/290746-viewing-angle-not-clear/#findComment-3947753
Well most TN monitors are rated with a viewing angle of exactly that, but usually it's at lease half that or a tad more, but yes, that's a good viewing angle. :)
ON A 7 MONTH BREAK FROM THESE LTT FORUMS. WILL BE BACK ON NOVEMBER 5th.
Advisor in the 'Displays' Sub-forum | Sony Vegas Pro Enthusiast & Advisor
  Tech Tips Christian Fellowship Founder & Coordinator
https://linustechtips.com/topic/290746-viewing-angle-not-clear/#findComment-3947757
Viewing angles only matter if you have more than one monitor IMO, or if it's mounted as a TV. If it's in front of you should be fine to move it so it's correctly positioned.
This. If you just sit in front of it and look at it head-on it's fine.
https://linustechtips.com/topic/290746-viewing-angle-not-clear/#findComment-3947788
