So every time I restart my computer, I have to resinstall the plugin for bf3 and bf4 for whatever reason.  Also, now when I click to download, it downloads, I open the file, run the installation, the bare goes about an 1/8 of the way and stops. It will no longer install and now I have 2 games that don't work.  Someone please help.
https://linustechtips.com/topic/290543-bf34-plug-in-problem/
Which browser? Some don't open or run the file because of security reasons. So you have to either go to DL folder and run it as admin. Or open browser as admin and drag and drop file into plugin page of browser.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/290543-bf34-plug-in-problem/#findComment-3946850
Do you have AddBlock or something similair? It prevents the use of plugins. This might be the problem you have, as I had that problem aswell.
Try it and let us know if it did the trick!
Main rig / To swap the 970 for a ref card?!
https://linustechtips.com/topic/290543-bf34-plug-in-problem/#findComment-3947210
Yeah. I do have adblock. I'll try it again without it. Thanks!
Chrome
https://linustechtips.com/topic/290543-bf34-plug-in-problem/#findComment-3948307
Isnt your antivirus stopping it? I use chrome and i had warning from my antivirus, i just ignored it and keep using the plugin.
Connection200mbps / 12mbps 5Ghz wifi
My baby: CPU - i7-4790, MB - Z97-A, RAM - Corsair Veng. LP 16gb, GPU - MSI GTX 1060, PSU - CXM 600, Storage - Evo 840 120gb, MX100 256gb, WD Blue 1TB, Cooler - Hyper Evo 212, Case - Corsair Carbide 200R, Monitor - Benq  XL2430T 144Hz, Mouse - FinalMouse, Keyboard -K70 RGB, OS - Win 10, Audio - DT990 Pro, Phone - iPhone SE
https://linustechtips.com/topic/290543-bf34-plug-in-problem/#findComment-3948523
