I recently did a client build inside of the Air 540 cube case and I absolutely adored building in it. I personally own an Antec 900 and I've had issue after issue with that case and I'm considering switching my build over to an Air 540. Are there any other similar cases are that are better or that I should know about?
https://linustechtips.com/topic/290370-air-540-best-cube-case/
for me it is the best cube case at this price
CPU:AMD FX-8320, RAM:Kingston Fury Black Series 8GB (1 x 8GB) DDR3-1600, GPU:MSI Radeon R9 280, Case:Cooler Master 690 III, PSU:Thermaltake Smart 650W
Storage:WD Purple 1TB, CPU Cooler:Hyper 212 EVO, Keyboard:SCI Granite, OS:win 8.1 64bit, Display:Samsung SyncMaster SA100, Mouse:CM Storm Spawn
https://linustechtips.com/topic/290370-air-540-best-cube-case/#findComment-3942742
i personally think the best cube case is this one as far as just the case not price
http://www.newegg.com/Product/Product.aspx?Item=N82E16811112456&cm_re=lian_li-_-11-112-456-_-Product
for price its a toss up between that and the cooler master HAF XB
But i think the looks of the Air 540 are nice especially the silver one
https://linustechtips.com/topic/290370-air-540-best-cube-case/#findComment-3942774
That's a link to a graphics card, not a case?
https://linustechtips.com/topic/290370-air-540-best-cube-case/#findComment-3942783
The Mercury S8 from Caselabs  is good but it is expensive
https://linustechtips.com/topic/290370-air-540-best-cube-case/#findComment-3942836
Agreed. My only gripe is the exposed HDD bays.
Bert & Ernie before squirting spermie.
https://linustechtips.com/topic/290370-air-540-best-cube-case/#findComment-3942841
  • 6 months later...
