I don't need them?
I wouldn't know why you would need them. The only thing they do is protect your case paint from getting damaged by the screws
https://linustechtips.com/topic/290340-h60-2013-help/#findComment-3942386
And I don't know if your H60 pump makes noise running at either full speed at mobo or 12 volt. But I got it running at 7 volt and it is deadly quiet. :D
(most people have problems with the h60 making noise)
https://linustechtips.com/topic/290340-h60-2013-help/#findComment-3942442
It's very quiet. I'm loving it,thanks for the help  :D
https://linustechtips.com/topic/290340-h60-2013-help/#findComment-3979326
