Hi
So I have This laptop with specs as follows,
i5-3210m 2.5GHz - 3.1GHz Turbo
AMD Radeon 7670m 1GB
8GB 1600Mhz DDR3 RAM
500GB 5400rpm HDD Seagate
Basicly Its an
HP Pavillion g6 2132se Laptop (NOT FOR GAMING) But I got it for that Purpose anyway 2 YEARS ago
(I cant game very wellon this now i got AC unity didnt even bother to run on this)
Now there is a new thing in Markets called The eGPU or external GPUs
My Question is that Will it work with my system regardless that I remove the wifi adapter to put in the MPCIE Connector
what will be most well suited GFX card and what resolution Monitor I should get was thinking of a 900p one
or should I do this at all or NOT
Thank you
https://linustechtips.com/topic/289833-egpu-diy-solution/
Get 1080p monitor
How will that help My CPU Has GD 7 ON Gamedebate and mostly is not recomended for gaming and my Question is Weather to get it or not and WHAT GPU Is good for this with the least amount of Bottlenecks
and OK I WILL GET A 1080p Monitor
Thank You
https://linustechtips.com/topic/289833-egpu-diy-solution/#findComment-3935287
Thank You
I really didn't understand that.
I would not recommend an egpu set up.
I would recommend something else.
What is your budget?
https://linustechtips.com/topic/289833-egpu-diy-solution/#findComment-3935331
Not Much For this laptop If you Recomend a 1080p monitor ill just make the setup and hook it up to my TV and Why do u not recomend eGPU
Is there any thing wrong with it that don't know of.
And If you dont recomend EGPU what will You recommend me to get i am pretty sure ill find a way to make the budget thats not a very big deal
At This Stage I am Mostly Open For Suggestions
Thank You
https://linustechtips.com/topic/289833-egpu-diy-solution/#findComment-3935372
Thank You
I said 1080p if you get egpu,u don't want 900p.
Now, why I don't recommend egpu.
It's very difficult, you need to know what you are going.
It's expensive.
It doesn't work 100%
https://linustechtips.com/topic/289833-egpu-diy-solution/#findComment-3935384
Thank You
country and currency?
maximum budget?
if things work out well you'll have alaptop and a mid range gaming desktop. best of both worlds. :)
Watch out for each other. Love everyone and forgive everyone, including yourself. Forgive your anger, forgive your guilt. Your shame. Your sadness. Embrace and open up your love, your joy, your truth, and most especially your heart.
-Jim Hensen
https://linustechtips.com/topic/289833-egpu-diy-solution/#findComment-3935398
It's expensive.
eGPUs are extremely hard to setup, i second that.
-Jim Hensen
https://linustechtips.com/topic/289833-egpu-diy-solution/#findComment-3935404
it'd be much easier to just build a seperate pc, and have the laptop still be garunteed to work.
-Jim Hensen
https://linustechtips.com/topic/289833-egpu-diy-solution/#findComment-3935408
It's expensive.
OK Difficult is not a problem but Cash somewhat is and I can not buy a new Desktop or even change the Laptop but with a few Savings I thaught of getting an r9-270 GPU as its Good and doesn't Bottleneck my CPU even though my CPU will Bottleneck that Card
https://linustechtips.com/topic/289833-egpu-diy-solution/#findComment-3935418
eGPUs have been known to be driver limited by AMD/NVIDIA.  They require some firmware/software tricks to get working.
We tried this once and had to abandon it after 3 days of trying.
@TechBenchTV
Ex-NCIX Tech Tips Producer.  Linus hates my scripts.
https://linustechtips.com/topic/289833-egpu-diy-solution/#findComment-3935429
it really is better to just do what im doing, and build a separate machine.
eGPUs are no garuntee. and you could eriously mess your laptop up with it.
-Jim Hensen
https://linustechtips.com/topic/289833-egpu-diy-solution/#findComment-3935442
maximum budget?
I Live in UAE and things ike eGPUs are Hard to find here I will have to get it ordered from Amazon and I have a Few Ideas of setting it up and I can spare a mPCI slot in my laptop
Budget is that i can get me a r9 270 GPU and a PSU for that and hook it up to my TV and Game NOT caring much About display latency and Refresh rates if it fells chopy ill get a monitor
There is also a big second Hand PC part Mall type thing here and I have 1500 AED makes around 410 USD
https://linustechtips.com/topic/289833-egpu-diy-solution/#findComment-3935451
AHH sir a few weeks ago I pulled apart my laptop head to tow to clean up its Vents and change the CPU Thermal Paste I think I can Handle it Thanks for the heads up
and how can u make gaming PC in this minute price
https://linustechtips.com/topic/289833-egpu-diy-solution/#findComment-3935476
410 USD you can build a pretty good desktop, just gotta be a sale shark like i am. B)
i got a C2Q q8200 for 15$ USD and my 270x (really a7870 ghz) for 100$.
if you head onto the hot deals thread pool, check around on ebay and amazon, ect, you can get good parts for cheap.
-Jim Hensen
https://linustechtips.com/topic/289833-egpu-diy-solution/#findComment-3935488
if you want to get a 900p monitor for cheap, do it but get at least a 17 inch, or larger if you can, 17 inch is beautiful but 20 would be a bit easier to see farther objects in game, that way you can save to get a good build, or use your tv as a monitor.
Sources: im infront of 3 16:10 900p 17 inch monitors right now, they have better pixel density than a 27 inch 1080p
https://linustechtips.com/topic/289833-egpu-diy-solution/#findComment-3935496
hm? something lost in translation i believe? *didnt quite understand that last sentance*
-Jim Hensen
https://linustechtips.com/topic/289833-egpu-diy-solution/#findComment-3935532
i love smaller sized surround estups, still badass and you can lower the resolution and get better FPS without losing buety. :F
-Jim Hensen
https://linustechtips.com/topic/289833-egpu-diy-solution/#findComment-3935542
D
Dear Good Kind Sir I know but I live in UAE not USA so noebay and amazon here and also these parts are really not available here and even if they are they have prices that are well above there actual ones on amazon as i know i  follow amazon almost daily (for no use)  EVERY THING OVER PRICED AND HIGHLY RARE HERE nothing comes cheap when you live in an ARAB country
https://linustechtips.com/topic/289833-egpu-diy-solution/#findComment-3935560
http://pcpartpicker.com/p/sfcTD3
stock cooler is enough for a mild over clock. (and i do mean mild, but everyone feels a little different about temps)
the 260x is good for the money, there are better values but not in this price range unless you find a deal somwhere.
-Jim Hensen
https://linustechtips.com/topic/289833-egpu-diy-solution/#findComment-3935576
D
oh. :'c
well, you can try the eGPU but again, its a no garuntees thing. :/
i have a firend who lives in isriel, ****'ing hundreds upon hundreds more than everywhere else. T^T
-Jim Hensen
https://linustechtips.com/topic/289833-egpu-diy-solution/#findComment-3935592
