I have the NZXT H440 the 4790k (at Stock) and my cooler is a Swiftech H240-x
During Idle I can get anywhere from 50-70C. During Furmark CPU Stress test I get stable 70C furing Cinebench no more than 50C and during Prime 95 my CPU goes from whatever it was sitting at to 99C and then starts to climb more.
IDK what is going on. I re-seated the cooler on the CPU. I changed the Thermal paste to IC Diamond. I cant even OC this thing because of the stupid temperatures. Please help
I havent a clue what is going on.
https://linustechtips.com/topic/289556-pc-temps-are-very-high/
First things first, never use prime95 again, it over volts the crap out of haswell based cpu's. It will hurt your cpu if you keep running it. Use Intel extreme tuning utility or aida64 instead. Secondly idle  temps are not really important. however 70c isn't that terrible for stock clocks. It's a 4.4ghz turbo. So try to overclock what you can and see how high the voltage can go before heat becomes on issue in cpu benches. If you can push it to 1.3v and still stay under 84ish you are still in perfectly reasonable temp zones for realistic workloads.
Ryzen 3700x -Evga RTX 2080 Super- Msi x570 Gaming Edge - G.Skill Ripjaws 3600Mhz RAM - EVGA SuperNova G3 750W -500gb 970 Evo - 250Gb Samsung 850 Evo - 250Gb Samsung 840 Evo  - 4Tb WD Blue- NZXT h500 - ROG Swift PG348Q
https://linustechtips.com/topic/289556-pc-temps-are-very-high/#findComment-3931484
Don't use Prime on Haswell CPUs. Use Intel Extreme Tuning Utility instead.
https://linustechtips.com/topic/289556-pc-temps-are-very-high/#findComment-3931490
On intel Extreme Tuning Utility CPU Benchmark I am getting temperatures at stock of 70c-80c
https://linustechtips.com/topic/289556-pc-temps-are-very-high/#findComment-3931575
