Streaming Build Help
Go to solution Solved by spartaman64,
Kingston ssdNow          u$ 114.-
Kingston HyperX Fury  u$135.-
Samsung 840 EVO      u$160.-
Crucial MX-100            u$145.-
Is there a big diference between all of these? These are the prices.
the mx100 is probably the best price per performance its write speed isnt that good but its read speed is awesome also wtf why is the hyperx fury read speed so slow
Hi,
I'm getting money to build a new rig, i will be using it mainly for gaming and streaming games like Battlefield 4, League of Legends, Hearthstone.
I live in Argentina, so everything here is very expensive, i have $1300. I think that i don't need a expensive GPU because i only play in 720p.
I was thinking in something like this:
Asus M5A97 R2.0 970 Sata3 USB3 u$ 180.-
AMD Six-Core FX-6300 3.5Ghz X6 8Mb Cache AM3+ u$ 180.-
GSkill DDR3 2x4Gb 1600Mhz Sniper u$ 145.-
Zotac Geforce GTX 750Ti 2Gb GDDR5 u$ 270.-
Sentey Solid Power 650w u$ 150.-
Corsair Cooling Hydro Series H60 Liquid CPU Cooler u$ 140.-
Kingston SSD ssdNOW V300 120Gb Sata3 2.5 u$ 114.-
Aerocool VS-92 Black Edition u$ 130.-
TOTAL: u$ 1310.-
For at least a month i will use a SSD as main drive and then i will get a 3tb hdd maybe, but i only have 3 games so i think that 120Gb will be enough. What do you think about this? Maybe with that Motherboard and that corsair h60 i can overclock the FX 6300 to 4.3Ghz and it will be enough? I'm not good with computer stuff D:
Sorry for my bad english.
Thanks.
https://linustechtips.com/topic/289161-streaming-build-help/
Do you think it is better to get a XFX 550w? with 80+ Bronze i think.
it depends on your plans. if you are planning to get something like a r9 390 later you will need the 600w if not then 550w will be more than enough for your current setup
https://linustechtips.com/topic/289161-streaming-build-help/#findComment-3925874
samsung ssds here are more expensive and perform worse than the mx100 not sure about the price over there
https://linustechtips.com/topic/289161-streaming-build-help/#findComment-3925951
https://linustechtips.com/topic/289161-streaming-build-help/#findComment-3926010
Ok, thanks a lot i will be getting this probably next week.
just a little heads up for some reason the write speed on the mx100 is extremely slow but that shouldnt be a problem unless you constantly move large files from your hard drive to ssd
https://linustechtips.com/topic/289161-streaming-build-help/#findComment-3926043
I'll only have the OS and 2 games probably, thanks for the advice.
https://linustechtips.com/topic/289161-streaming-build-help/#findComment-3926081
