planning my first pc build and looking for ways I can save some money on it. I designed it to be upgradable and would like it to stay that way. Otherwise if im doing anything wrong please tell me I don't want to mess this up.
This is the link:https://uk.pcpartpicker.com/user/theofry101/saved/ZDxtt6
https://linustechtips.com/topic/289047-need-help-saving-money/
What kind of upgrades did you have in mind?
What's the system being used for? Why the aftermarket cpu cooler?
https://linustechtips.com/topic/289047-need-help-saving-money/#findComment-3924246
If the build is designed to be upgradable don't skimp on the case (and PSU). A good case can last you many many years
Asrock 890GX Extreme 3 - AMD Phenom II X4 955 @3.50GHz - Arctic Cooling Freezer XTREME Rev.2 - 4GB Kingston HyperX - AMD Radeon HD7850 - Kingston V300 240GB - Samsung Spinpoint F3 1TB - Chieftec APS-750 - Cooler Master HAF912 PLUS
osu! profile
https://linustechtips.com/topic/289047-need-help-saving-money/#findComment-3924280
What do you have against In win? They make good cases, they might not be the best looking but they're solid
Nothing. I was just making a general point that's all.
osu! profile
https://linustechtips.com/topic/289047-need-help-saving-money/#findComment-3924339
Ssd's, more memory, possibly another gpu and a optical drive. The cooler is so I can safely overclock it
cant overclock a i3 and b85 is a locked platform
what is your opinion on buying used parts
My Rig
PCPartPicker part list: http://ca.pcpartpicker.com/p/kGNksY
CPU: Intel Core i7-4770 3.4GHz Quad-Core Processor  ($379.00 @ shopRBC)
CPU Cooler: RAIJINTEK THEMIS 65.7 CFM Sleeve Bearing CPU Cooler  ($34.99 @ NCIX)
Motherboard: MSI CSM-H87M-G43 Micro ATX LGA1150 Motherboard  ($78.83 @ DirectCanada)
Memory: Kingston HyperX 16GB (4 x 4GB) DDR3-1600 Memory  ($139.99 @ Memory Express)
Storage: Kingston Fury 120GB 2.5" Solid State Drive  ($71.34 @ DirectCanada)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($92.95 @ Vuugo)
Video Card: Gigabyte Radeon R9 280X 3GB Video Card  ($298.98 @ Newegg Canada)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case  ($125.98 @ Newegg Canada)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($66.99 @ NCIX)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit)  ($116.00 @ shopRBC)
Case Fan: Cougar Turbine 120 (4-Pack) 60.4 CFM 120mm  Fans  ($23.99 @ NCIX)
Monitor: HP 22xi 60Hz 21.5" Monitor  ($187.11 @ Amazon Canada)
Keyboard: Logitech G710 Wired Gaming Keyboard  ($114.99 @ NCIX)
Mouse: Razer DeathAdder 2013 Wired Optical Mouse  ($76.99 @ Amazon Canada)
Headphones: Kingston HyperX Cloud Pro Headset  ($78.98 @ DirectCanada)
Total: $2074.22
Prices include shipping, taxes, and discounts when availableGenerated by PCPartPicker 2015-04-10 15:33 EDT-0400Build log http://linustechtips.com/main/topic/303263-the-dell-from-hell/#entry4121100
Phone Compassion Spreadsheet https://docs.google.com/spreadsheets/d/1EN6s426gyxqPloIqT4wQ7Y7yovkkQy_5B3djVN-N-R8/edit#gid=0
Gta V Pc Online Crew http://linustechtips.com/main/topic/344773-unofficial-linus-tech-tips-gta-v-crew-pc/
https://linustechtips.com/topic/289047-need-help-saving-money/#findComment-3924379
cheaper, and for only gaming and school, this will be fine. a little later when you get some more money you can upgrade the cpu, since it is z97 you could go broadwell. and i got a good psu for you so you can get another gpu
Motherboard: MSI Z97 PC MATE ATX LGA1150 Motherboard  (£64.54 @ Ebuyer)
Memory: Kingston Predator Series 8GB (2 x 4GB) DDR3-1600 Memory  (£44.37 @ PC World Business)
Video Card: MSI Radeon R9 280X 3GB TWIN FROZR Video Card  (£179.14 @ Scan.co.uk)
Case: NZXT S340 (Black) ATX Mid Tower Case  (£59.94 @ Scan.co.uk)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  (£71.60 @ Amazon UK)
Monitor: BenQ GW2255 60Hz 21.5" Monitor  (£80.40 @ Kustom PCs)
Wireless Network Adapter: Asus PCE-N15 802.11b/g/n PCI-Express x1 Wi-Fi Adapter  (£15.58 @ Scan.co.uk)
Total: £709.24
Generated by PCPartPicker 2015-01-11 19:52 GMT+0000
My Rig
Total: $2074.22
https://linustechtips.com/topic/289047-need-help-saving-money/#findComment-3924522
CPU: Intel Pentium G3258 3.2GHz Dual-Core Processor  (£49.14 @ Aria PC)
Storage: Sandisk Solid State Drive 128GB 2.5" Solid State Drive  (£42.98 @ Ebuyer)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (£40.39 @ Aria PC)
Power Supply: Antec High Current Gamer 750W 80+ Bronze Certified ATX Power Supply  (£61.16 @ Scan.co.uk)
Total: £709.24
can I overclock this and if so will I need a better cooler
https://linustechtips.com/topic/289047-need-help-saving-money/#findComment-3924926
yes you can, you can do a little on the stock cooler otherwise get a 212 evo
My Rig
Total: $2074.22
https://linustechtips.com/topic/289047-need-help-saving-money/#findComment-3925019
what's a 212 evo?
coolermaster cooler
My Rig
Total: $2074.22
https://linustechtips.com/topic/289047-need-help-saving-money/#findComment-3925094
