Hi. All this week I was trying to build my first gaming pc. I got my MOBO, GPU, CPU, RAM, case, but its so complicated when it comes to ordering those parts. In UK it costs about 600 dollars, in UK about 500 pounds, in Germany about 700 euros.
Is this build worth buying?
CPU: Intel Core i5-4440 3.1GHz Quad-Core Processor  ($174.99 @ NCIX US)
Motherboard: Asus Z97-A ATX LGA1150 Motherboard  ($128.99 @ NCIX US)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1866 Memory  ($84.88 @ OutletPC)
Storage: Samsung Spinpoint F1 DT 1TB 3.5" 7200RPM Internal Hard Drive  ($102.74 @ Amazon)
Video Card: MSI Radeon R9 270X 2GB TWIN FROZR Video Card  ($164.99 @ Newegg)
Total: $656.59
Generated by PCPartPicker 2015-01-11 05:46 EST-0500
Maybe you have better suggestion ?
https://linustechtips.com/topic/288787-need-help-with-gaming-pc/
" In UK it costs about 600 dollars, in UK about 500 pounds!
Did you mean Us and Uk instead of Uk and Uk?
Besides that, the pc looks great.
I am not sure how good Samsung hdds are though I have never seen a person use it in a build.
And I highly recommend sapphire 270(x) after seeing the temps of it in my brother's computer.
PC  Specs 2022:
  • CPU
    AMD Ryzen R9 5900x @ 5.1GHz - Auto OC
  • Curve Optimizer Magnitude: -20
  • Motherboard
    ASUS ROG STRIX x570-F Gaming
  • RAM
                                        Kingston Fury 32GB DDR4 3200MHz 16x2GB
  • GPU
    MSI 3070 8GB Ventus 2x OC
  • Case
    LIAN LI LANCOOL MESH II Mesh RGB Black
  • Storage
    Kingston NV1 2TB M.2. NVMe
  • PSU
    Seasonic Focus GX 850w
  • Display(s)
    MSI OPTIX MAG 251RX IPS 240hz & ASUS MG248Q Vertical 144hz & Dell 60hz
  • Cooling
    NZXT Kraken x73 360mm
  • Keyboard
    Tt eSports Meka G1
  • Mouse
    Logitech G Pro Wireless
  • Operating System
    -Windows 10 Professional 64bit
https://linustechtips.com/topic/288787-need-help-with-gaming-pc/#findComment-3920909
Get a cheaper CPU,RAM and motherboard and get a better GPU.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/288787-need-help-with-gaming-pc/#findComment-3920922
Why overclock mobo if you have non-overclock CPU?
Go for Gigabyte G1.Sniper B5 as mobo, €70 (in Netherlands)
For RAM Crucial Ballistix Tactical BLT2C4G3D1608ET3LX0CEU (2x 4GB) because it's low voltage and it's cheaper €67 (in Netherlands)
And for HDD WD Blue WD10EZEX, 1TB €55 (in Netherlands)
Do you have a case or you need a case?
In the future I advise buy a SSD for windows or playing often games and games have advantage of using a SSD.
Goodluck mein freund ;)
Edited by DutchRedGaming
https://linustechtips.com/topic/288787-need-help-with-gaming-pc/#findComment-3921082
No, i don't have a case.I' am searching for it right now. Thanks for your tips ;)
https://linustechtips.com/topic/288787-need-help-with-gaming-pc/#findComment-3921223
Search for case with ATX to match with motherboard and 2 fans for the air flow. One of the cheapest is Cooler Master N300 (closed) for €30 (in Netherlands)
Source (Site in Dutch)
https://linustechtips.com/topic/288787-need-help-with-gaming-pc/#findComment-3921259
