Well, there's this
http://docs.oracle.com/javase/tutorial/
But the way I did it was like so:
First this tutorial which I really liked. Gets you more familiar with the syntax and stuff
http://profs.etsmtl.ca/mmcguffin/learn/java/
Note that it teaches how to write applets which are slightly different from standalone apps
Next I wanted to do a GUI so I went here
http://docs.oracle.com/javase/tutorial/uiswing/index.html
Also, the graphics teaching of the quick and dirty second link is a little outdated now and newer ways of doing it are here:
http://docs.oracle.com/javase/tutorial/2d/index.html
And later looked up everything else I ever needed in the first link too.
I cannot be held responsible for any bad advice given.
I've no idea why the world is afraid of 3D-printed guns when clearly 3D-printed crossbows would be more practical for now.
My rig: The StealthRay. Plans for a newer, better version of its mufflers are already being made.
Java is hell to learn from code. It's so convoluted that by the time you get to the good stuff, you're already a few hundred lines down. That makes it difficult to learn from example (which is how I learn). I'd say that the 2nd best way to learn it would be to follow a tutorial series on YouTube on different projects and learn techniques from there.
I use a Lenovo T440: i5 4300U, 8GB RAM, 128GB Samsung 840 Evo, 14" 900p display and an external 23" 1080p passive 3D monitor. Extended 6-cell battery with internal 3-cell. Ubuntu 14.04 LTS (I only use open-source software -- haven't paid for a single program yet).
Some tutorials:
Some courses:
If you haven't done so already you should visit the Ultimate Programming Resource Thread. There's a Java section listing some of these as well as other staple Java resources. Furthermore if you go through that thread you'll find some more Java related stuff that hasn't made it to the front page yet (it's maintenance is being taken over so it should get an update shortly).
IntelliJ is by far the best IDE for Java (IMO) out there, it's done by JetBrains and is built upon their industry leading ReSharper technology.
The single biggest problem in communication is the illusion that it has taken place.
I think you should learn coding practices in general. Like coding standards and so on, try to work with a specified design, you can try to find some well coded opensource projects (best smaller for learning purposes) and read their code, try to figure out why some decisions were made and so on. The thing about learning this is that the knowledge will carry to any other languages you learn, though designs vary, you will figure them out more quickly as you go. The first thing to start on - write beautiful code.
Not a Java article, but a good one nontheless: http://kotaku.com/5975610/the-exceptional-beauty-of-doom-3s-source-code
Well, I hope that replied to your question. You say you are decent at programming and reading Java, so it's time to move on!
