Hello all, I have big doubt that would appreciate some help with.
I currently have 3x 22 inch 1080 lcd monitors. The downside of these monitors is that they only have a VGA connection.
I am planing to buy a gaming rig with an Nvidia GTX970.
http://us.msi.com/product/vga/GTX-970-GAMING-4G.html#hero-overview
So the card comes with:
》1xDVI-I port (can be adapt to VGA).
》1xHDMI port (can be adapt to VGA).
》1xDisplayPort (can be adapt to VGA).
》1xDVI-D (cannot be adapt to VGA).
Their website says that supports a maximum of 4 monitors.
Does anybody know for sure if with this setup I will be able to play "surroud gaming" @ 1080? Or maybe if I will definitely not be able.
Thanks a lot...
https://linustechtips.com/topic/288705-surround-gaming-with-vga/
Thanks a lot...
HDMI can't be adapted to VGA without a signal converter, same thing with DisplayPort and DVI-D. You should be able to configure them in surround if you can get them working, but I haven't tried personally.
https://linustechtips.com/topic/288705-surround-gaming-with-vga/#findComment-3919663
I don't see why not, doesn't hurt to try.
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
https://linustechtips.com/topic/288705-surround-gaming-with-vga/#findComment-3919668
Thank you guys for the replies, but this raised more questions for me. This is what I had in mind:
- DVI to VGA cable: http://www.amazon.com/eforCity-TOTHDVIVGA10-DVI-I-Cable-10-Feet/dp/B005QWH532/ref=sr_1_3
- HDMI to VGA cable: http://www.amazon.com/Gold-plated-Connector-Converter-Hdmi1-3v-1080p-Abs-black/dp/B00KX047EW/ref=sr_1_3
- DisplayPort to VGA cable: http://www.amazon.com/dp/B005RISB3S?psc=1
Can you please explain the term "active"?
I understand that it probably means some kind of circuitry in the middle to help with the conversion of the signal, but is it really necessary and does it improve anything?
Would you recommend different cables or converters? Why?
I like the 10 feet (at least) cables for proper cable management and not to limit the position of my case.
Thanks!
https://linustechtips.com/topic/288705-surround-gaming-with-vga/#findComment-3921604
PLEASE dont get those "hdmi to vga adapters"
There fake. VGA is analog and HDMi Is digital. Theres no way that cable will work. Get this:
http://www.amazon.com/dp/B006LP0FXA?psc=1
My Main Build: NZXT S340 - NZXT Kraken X31 - Crucial MX100 256GB - i5 4460 - Gigabyte Z97P D3 - Kingston HyperX Red 8GB - MSI Nvidia GTX 780 3GB - Corsair LL & HD RGB Fans, Corsair Lighting Node Pro.
https://linustechtips.com/topic/288705-surround-gaming-with-vga/#findComment-3930063
