so my friend is thinking about buying my old GTX 650 Ti but i want to make sure it will work with his PC before he buys it i found out he has a 300W PSU so i wanted to make sure that he will be able to use the GTX 650 ti because i thought it would be cutting it a bit close i have also told him that it might bottleneck a bit but what do u guys think?
(Random zoostorm PC)
Specs
CPU: celeron g550 @ 2.6GHz
RAM: 8GB (unsure of make and model)
HDD: 1x 500GB
MoBo: Asus P8H61-MX R2.0
PSU: Random 300W PSU
Disc Drive: 1x random disc drive
i have tried making the build on pc part picker to try and get an idea on how much power it is already using but some of the specs are not on pc part picker
https://linustechtips.com/topic/288285-need-help-with-a-friends-pc/
That will not be enough imo. You will need 430W at least to make sure you have enough power.
Also the topic is in the wrong section of the forum.
CPU: AMD Ryzen 9 - 3900x @ 4.4GHz with a Custom Loop | MBO: ASUS Crosshair VI Extreme | RAM: 4x4GB Apacer 2666MHz overclocked to 3933MHz with OCZ Reaper HPC Heatsinks | GPU: PowerColor Red Devil 6900XT | SSDs: Intel 660P 512GB SSD and Intel 660P 1TB SSD | HDD: 2x WD Black 6TB and Seagate Backup Plus 8TB External Drive | PSU: Corsair RM1000i | Case: Cooler Master C700P Black Edition | Build Log: here
