I've been running F@h for 12 hours on medium power and it was kinda effecting the system stability. I know it is normal when running, but even after i closed f@h it was making some unstability (for ex. doing things that i don't do, or doing something wrong). Then i closed the computer for 30 minutes or so. After i booted up again everything was pretty normal.
Is it normal to have stability issues like that after running f@h for so long?
My "superultragamingpc" setup:
Core i3 3220
GA-B75M-D3V
HD6570
Corsair Vengeance 2x4GB 1600Mhz
https://linustechtips.com/topic/288121-fh-effects-system-stability-after-long-usage/
It shouldn't be affecting the stability that much, even after long runs, for example, I usually run for multiple days non-stop before I restart the PC without any hitches :/
Specs: CPU: AMD FX 6300 Motherboard: Gigabyte 970A DS3P RAM: HyperX Fury 16GB 1866MHz GPU: MSI R9 270 OC edition Case: Sharkoon VS3-S SSD: Samsung 840 EVO 120GB HDD: 1TB Caviar Blue PSU: Corsair CX500W
*If I say something that seems offensive, please don't take it seriously, it was most likely meant as a joke/sarcastically*
Could you define these "instabilities" what happened exactly?
was it gitching out(is so, how?) was it sluggish/slow, are you
sure it wasn't just placeo?(by that i mean bias) did you have
a memory leak or something else perhaps?
my pc has been on for over a month by now folding 24/7, no
problems.
folding could potentially interfere with daily use, becoming
sluggy/slow. but that isn't necessarily caused by some instability.
Edited by tobben
problems.
By instabilites, it was glitching, slugging a bit and everything was slow like i was still folding.
By glitching i mean, when i tried to move something on taskbar to left, it just screws it up, opens something that i don't click, randomly places everything etc.
This didn't ever happened before/after that day.
Well, that is a strange anomaly and not common as far as i am aware.
whether it was caused by folding or something else, or something else
on collaboration with folding i don't know.
Are you sure you closed/stopped folding properly and your gpu/cpu usage
dropped accordingly?
it would be worth looking at if it happens again and keeps being a problem.
Run something like HWmonitor, keep and eye on your temps...
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
the only problems i have is mouse lag , but that goes away after i stop folding with my cpu
Please quote me or tag me if your trying to talk to me , I might see it through all my other notifications ^_^
the current list of dead cards is as follows 2 evga gtx 980ti acx 2.0 , 1 evga gtx 980 acx 2.0 1600mhz core 2100mhz ram golden chip card ... failed hardcore , 1 290x that caught fire , 1 hd 7950 .
may you all rest in peaces in the giant pc in the sky
I've found it can cause some stability issues, but it's always fix with a restart. I'm not sure how much it has to do with actually folding. Hell, if I have a PC on windows running for a month or more without restart, it just needs to be restarted. Sometimes a week in some cases.
Why not check your hard drive health in CDinfo if you are not on an ssd? Sounds stupid, but if it hangs up after a while of being on and gives really low read/write spends and long response times, those things can happen.
Hell my OS drive in my desktop that I use for folding it starting to fail. Lots of reallocated sectors, ect ect.
It would be fine for a while on restart, then after a while of being on it would hang up a lot like that, and give 5 seconds plus response times. Pretty much the same symptoms.
Whether or not it's the problem, it's worth checking for piece of mind and just in case. Seeing a failure coming and imaging the drive is a lot better than recovering from backups.
