Hey guys im deciding between the corsair 760t white and the 780t white .. but ive heared that the 780t has problems fitting the asus maximus 7 formula is this true if it is would the 760t be a better option any help would be greatly appreciated thanks
I dont see why there would be any issues installing it into the 780t, as it is a standard ATX mobo.
My arsenal: i7-9700k Gaming Rig, an iPhone, and Stupidity.
https://linustechtips.com/topic/288062-need-help/#findComment-3912087
Both cases have the same size motherboard area. 9 slots. The Formula is only 10mm longer than standard ATX, which has 7 slots. It's also standard ATX width, so no problems there either.
INTEL CORE i5-7600K | ASUS ROG STRIX B250i GAMING | CRUCIAL BALLISTIX SPORT LT 16GB | EVGA GTX 970 SC | EVGA B3 550W
SAMSUNG 850 EVO 250GB | CRYORIG M9i | BE QUIET! PURE WINGS 2| FRACTAL DESIGN DEFINE NANO S
https://linustechtips.com/topic/288062-need-help/#findComment-3912143
Both cases have the same size motherboard area. 9 slots. The Formula is only 10mm longer than standard ATX, which has 7 slots. It's also standard ATX width, so no problems there either.             Thanks for the help so the mobos armor wouldnt block the stand off also is both of them have pre installed standoff
https://linustechtips.com/topic/288062-need-help/#findComment-3912199
The armours backplate doesn't interfere with the standoffs.
http://www.overclockingmadeinfrance.com/wp-content/uploads/2014/08/ASUS-Maximus-VII-Formula-9-750.jpg
https://linustechtips.com/topic/288062-need-help/#findComment-3912226
