I am almost done with my computer and now I am trying to find a way to make a drawer in my desk into a self made drawer case thing :P.  I am planning on doing something like this.  I would be adding a few more fans to it. But yeah post-19570-0-81603700-1371949206.jpg
i5 4670k| Asrock H81M-ITX| EVGA Nex 650g| WD Black 500Gb| H100 with SP120s| ASUS Matrix 7970 Platinum (just sold)| Patriot Venom 1600Mhz 8Gb| Bitfenix Prodigy. Build log in progress
Build Log here: http://linustechtips.com/main/topic/119926-yin-yang-prodigy-update-2-26-14/
https://linustechtips.com/topic/28794-custom-drawer-case/
You can take apart the drawer use the bottom piece and make stand offs for the mother board. Cut holes for the fans.
I took apart my old P.O.S. case and took the motherboard tray that i would mount it to.
https://linustechtips.com/topic/28794-custom-drawer-case/#findComment-366078
Thats awesome! The only thing I would be worried about is cooling....
It would be better cooling than my old case surprisingly.  I would mount 2 exhaust fans next to the dvd drive
https://linustechtips.com/topic/28794-custom-drawer-case/#findComment-366084
