so i am supposed to build a pc for my dad,not targetting at a gaming build just a low cost built with great multitasking performance so this is what i figured out
CPU: AMD 5350 2.05Ghz Quad-Core Processor  ($54.39 @ NCIX US)
Motherboard: Asus AM1M-A Micro ATX AM1 Motherboard  ($33.90 @ SuperBiiz)
Memory: Corsair 4GB (1 x 4GB) DDR3-1600 Memory  ($37.99 @ Newegg)
Power Supply: Corsair Builder 430W 80+ Bronze Certified ATX Power Supply  ($34.88 @ OutletPC)
Total: $212.04
Generated by PCPartPicker 2015-01-09 07:24 EST-0500
yes there should be faster memory,faster drive and 430w psu is too much but again this is the bang for the buck thing atleast in my country .... what do you guys recommend
https://linustechtips.com/topic/287560-simple-basic-office-build/
CPU: Intel Celeron G1820 2.7GHz Dual-Core Processor ($47.98 @ Newegg)
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard ($44.99 @ Directron)
Memory: G.Skill AEGIS 4GB (1 x 4GB) DDR3-1600 Memory ($31.45 @ Newegg)
Storage: Western Digital Caviar Green 1TB 3.5" 5400RPM Internal Hard Drive ($51.00 @ Amazon)
Case: Fractal Design Core 1000 USB 3.0 MicroATX Mid Tower Case ($34.99 @ SuperBiiz)
Power Supply: EVGA 430W 80+ Certified ATX Power Supply ($33.99 @ SuperBiiz)
Total: $244.40
Generated by PCPartPicker 2015-01-09 07:43 EST-0500
Steve
Total: $244.40
less cores but l3 cache but then i am scared about its performance in heavy gui based applications and depending on which my dad will judge me whether i really know about computers or not ..... :/
also explaining to him everything about that he really dosent need an i3 is one big thing i would have to deal with
APU then?
Steve
Hi there @switchkill!
I think this build will do a perfect job for office work. Nonetheless, the WD Green is a very good drive designed for storage purposes, and since it's boot drive you're looking for, I would recommend WD Blue which meant for everyday computing and will suit better. Here's a link where you can check it out:
Hope this helps.
Cheers! :)
If this post helped you, please like and choose it as a best answer.   :)
http://www.wdc.com/en/
http://products.wdc.com/support/kb.ashx?id=qmCv4n
Hope this helps.
Cheers! :)
I don't know if your industry affiliate or not since i am using tapatalk but,i have always preffered wd drives due to thier low faliure rates and awesome onsite warranty support,i would have gone with a blue drive since they are faster,but currently they are in shortage in my country and thus being overpriced since i had bought a blue drive few months ago at 40% less... It would be nice if wd solves this problem
Yes, I'm an official WD representative. :)
Can you send me a PM with your location and I'll discuss this matter with my colleagues?
Thank you for the support too, we appreciate it!
CPU: AMD A6-7400K 3.5GHz Dual-Core Processor ($61.98 @ OutletPC)
Motherboard: Asus A78M-E Micro ATX FM2+ Motherboard ($44.99 @ Newegg)
Storage: Western Digital Caviar Blue 320GB 3.5" 7200RPM Internal Hard Drive ($30.24 @ Amazon)
Case: Fractal Design Core 1100 MicroATX Mini Tower Case ($36.25 @ Directron)
Total: $238.90
Generated by PCPartPicker 2015-01-09 09:12 EST-0500
Steve
Total: $238.90
Actually the a6 wouldn't fit in the per pc budget since he would be getting 5 machines..... And 320gb won't be enough even 1tb isn't enough sometimes due to the amount of documents
Just go for the 5350 then... Or go on ebay and get some old prebuilts with core 2 duos
Steve
