psu changing input voltage
Go to solution Solved by dragoon20005,
yes all modern PSU are auto switching
I've moved from germany now, and found my psu is dual voltage 120v-240v. One problem I don't see a voltage switch on the psu its self. Wondering if this psu switches automatically?
http://www.inter-tech.de/index.php?option=com_content&view=article&id=671:coba-nitrox-nobility-800w-80-silber&Itemid=587〈=en
https://linustechtips.com/topic/287503-psu-changing-input-voltage/
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
