Hi everyone, so I have been using an old crappy and thin office mouse pad with my deathadder, for almost 4 months. I am looking to get a mouse pad that will work great with the Deathadder and would feel great and be great for gaming?
Budget goes up to $50 but I expect to spend around 20
Thank you,
Josh
https://linustechtips.com/topic/287429-need-mousepad-for-razer-deathadder/
I use an X-Trac Pad. They usually come in large, larger, and frickin' huge sizes...
I have a large one. It's like 14 inches across. Cloth topped.
My Deathadder loves it.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817114182&cm_re=x_trac_pads-_-17-114-182-_-Product
"A picture is starting to form here... I wonder if it's accurate? Some pieces don't quite seem to fit. Or maybe I just don't like the way it looks."
I have a Steelseries mouse pad that I just bought today from Best Buy for my Naga after not having a mouse pad for about four years. My performance in CS:GO decreased quite a bit actually, but after a little bit of negative reinforcement from my teammates I almost ended with a positive K/D in a competitive match.
It'll take some getting use to, but so far it's worked well for me I suppose. It's got like 12" x 10" dimensions or something so I definitely have enough real estate, and the surface seems good enough.
PCPartPicker link: http://pcpartpicker.com/p/R6GTGX
Привет товарищ ))))
Do you know how it would work with the Deathadder and if it would be a good option if I am coming for a 9X7in mouse pad ahah
Is there any issues with the optical sensor with the cloth? sorry but I am not very familiar with mouse pads.
I would assume so. Hell, that Amazon link has really huge dimensions so it should be good.
There shouldn't be. I'm taking a shot in the dark here because I'm no mouse pad expert either, but if your optical sensor is working fine with whatever surface you're using now, then it should be fine (or possibly better) with the cloth mousepad.
Привет товарищ ))))
Nope. I've never had an issue. My Deathadder actually has a harder time with the wood-grain pattern on my desk if I don't use a mousepad, but the pad I use is silky smooth.
They're pretty decent pads, imo.
cloth is what you need for optical since it's consistant. any orther surface can have more imperfections or be too smooth.
I'm a huge fan of the Goliathus, specifically the Control Edition
CPU: Intel Core i7-4770k | Mobo: MSI Mpower Max | Cooling: Cryorig R1 Ultimate w/ XT140 front Fan | GPU: EVGA GTX 770 Dual SC SLI | Case: NZXT H440 | Case Fans: Phanteks PH-140SP x5 | PSU: EVGA Supernova P2 1000W | RAM: 16GB Crucial Ballistix Tactical Tracer | SSD: Kingston HyperX 3k 120GB | HDD: Seagate Barracude
Keyboard: Razer Blackwidow Ultimate 2013 | Mouse: Razer Deathadder 2013 | Headphones: Sennheiser HD438s | Mousepad: Razer Goliathus Control | Monitor 1: Benq XL2430T | Monitor 2: BenQ RL2455HM
