Do you have any suggestions i would really appreciate it
CPU:4790k
RAM: 8x2 Corsair Vengeance Pro
GPU: EVGA gtx980 superclocked
Motherboard: ASUS MAXIMUS VII HERO Z97
Case: CM Storm Scout 2
Storage (SSD): Samsung 840 EVO 500GB
Storage (hard drives): Western Digital Caviar Green 3
PSU:Corsair HX850i
CPU cooler: Cooler Master V8 GTS
https://linustechtips.com/topic/285847-my-first-ever-build/
Pretty Big first build!!!
CPU: Intel Core I5 4590 | GPU: EVGA GTX 970 SSC | Mobo: ASRock Fatality H97 Performance | Ram: HyperX Fury 8gb 1866 | SSD: Intel 520 series 240 GB | HDD: WD Blue 1TB | Case: Aerocool DS 200 red/black | Cooler: Coolermaster Hyper 212X | PSU: Antec High Current Gamer 620w | Monitor: AOC i2367fh & old HP | OS: Windowws 7
https://linustechtips.com/topic/285847-my-first-ever-build/#findComment-3881301
Welcome to the Forum.
My suggestion is to use PCPartPicker. I'll make the list for you.
According to PCPP the cooler you chose isn't compatible with the case you chose.
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($318.99 @ SuperBiiz)
CPU Cooler: Cooler Master V8 GTS 82.0 CFM CPU Cooler  ($74.99 @ Newegg)
Motherboard: Asus MAXIMUS VII HERO ATX LGA1150 Motherboard  ($209.99 @ Amazon)
Storage: Samsung 840 EVO 500GB 2.5" Solid State Drive  ($219.99 @ Amazon)
Total: $1897.92
Generated by PCPartPicker 2015-01-06 17:04 EST-0500
Sig under construction.
https://linustechtips.com/topic/285847-my-first-ever-build/#findComment-3881337
Total: $1897.92tPrices include shipping, taxes, and discounts when available
thanks
https://linustechtips.com/topic/285847-my-first-ever-build/#findComment-3881427
gaming and video editing
Change to a cpu cooler that fits in the case. NH-U12S would be a decent choice. Or change to a case that can has a max cpu cooler hight > 167 mm.
The psu capacity is a fair bit more than needed. Even if a second gpu were to be added.
https://linustechtips.com/topic/285847-my-first-ever-build/#findComment-3881506
That would be a good idea, but he needs to consider if he wants to overclock
He has an AX760i. That's $185 on NewEgg. A RM750 is $120, $99 after rebate. My point was that the PSU is pricey just for a better name and a slightly better 80+ rating.
My arsenal: i7-9700k Gaming Rig, an iPhone, and Stupidity.
https://linustechtips.com/topic/285847-my-first-ever-build/#findComment-3881536
Oh, yeah. I was replying to the part of "and get an H55 or another AIO." :P
https://linustechtips.com/topic/285847-my-first-ever-build/#findComment-3882271
