Biggggg Problem help!,!,!,!,!,!,!,!,!,!,!,,,,!,
Tell us what hardware you have
Case: Phanteks Evolve X with ITX mount  cpu: Ryzen 3900X 4.35ghz all cores Motherboard: MSI X570 Unify gpu: EVGA 1070 SC  psu: Phanteks revolt x 1200W Memory: 64GB Kingston Hyper X oc'd to 3600mhz ssd: Sabrent Rocket 4.0 1TB ITX System CPU: 4670k  Motherboard: some cheap asus h87 Ram: 16gb corsair vengeance 1600mhz
https://linustechtips.com/topic/285819-biggggg-problem-help/#findComment-3880811
try clearing your boards cmos.
https://linustechtips.com/topic/285819-biggggg-problem-help/#findComment-3881054
in the BIOS look for boot options
there will be a list for you to edit the boot order
select your HDD as the first boot device
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/285819-biggggg-problem-help/#findComment-3882976
8GB ram ddr3
Intel Core i5-3330 CPU @ 3.00GHz 4 Cores
AMD HD 6670 2GB
2 TB of memory
PSU: Channel well technology, 450w Max 220v 47-63 Hz
Motherboard: MSI H61mp31/w8
Items to be upgraded:
2 TB of memory...LOL!!!  I know what you meant,  I how many HDD's or sdds are installed?
one day 2TB ddr20 will be the standard...;)  :D
https://linustechtips.com/topic/285819-biggggg-problem-help/#findComment-3886129
