my new power supply has bin having buzzing sounds and grinding sometimes is it bad or is it ok for me to keep using it
it doesn't overheat or get hot but i'm worried
https://soundcloud.com/depression09/pc-power-supply-sounds-2
here's what it sounds like only the first 4 secs can be heard
https://linustechtips.com/topic/285659-power-suppy-noises-when-under-load/
That's called coilwhine it's completely normal.
Sounds like a coil whine to me. If it is really coil whine then there is nothing wrong with it except it can be annoying... if you can return it and get replacement I would do so if you are willing to be without PC for a while.
No please
Unlucky but yeah its fine to use
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
Yes, I listened but it could be a some small fan noise.
your completely sure it's only coil whine?
https://soundcloud.com/depression09/audio-recording-on-tuesday
sounds like a Hard drive to me, are you sure its from your PSU?
try to turn off your fans
        Sample Text ( ͡° ͜ʖ ͡°)
