Low-mid range build.
Go to solution Solved by c0d0ps,
Thank you but adding this will kind of throw me off my budget. even with 60k
https://pcpartpicker.com/user/c0d0ps/saved/#savedbuild_1870487
How about this?
585,16$=37036,08unr
So I am building a new system for my birthday and have almost finalized my build
CPU : AMD 3.5 AM3+ FX 6-Core Edition FX-6300
Motherboard : Asus M5A97 Motherboard 2.0
GPU : Sapphire AMD/ATI Radeon Dual-X R9 270X
RAM : Corsair Vengeance DDR3 8 GB (1 x 8 GB) + Samsung 6 GB (1 x 4GB + 1x GB) [from my old system]
Storage: Samsung 840 Evo 120 GB  + WD Caviar Blue 500 GB [Again from my old system]
PSU : Corsair V650 650 Watt Power Supply
Case: HAF 912
How good is this configuration? What type of FPS can I expect in BF4? And how good will be for streaming or recording without a capture card?
Thanks in advance
https://linustechtips.com/topic/285637-low-mid-range-build/
Location and budget?
But it looks pretty good -- although there may well be better options depending on your location/budget.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/285637-low-mid-range-build/#findComment-3878054
Case: HAF 912
Thanks in advance
For b4 you can do high 60+ fps I think. And ultra avg ca 50
Unless you plan on using psu for future build, 500w is enough.
270x doesn't require much.
650w is like for 290x or something.
PC  Specs 2022:
  • CPU
    AMD Ryzen R9 5900x @ 5.1GHz - Auto OC
  • Curve Optimizer Magnitude: -20
  • Motherboard
    ASUS ROG STRIX x570-F Gaming
  • RAM
                                        Kingston Fury 32GB DDR4 3200MHz 16x2GB
  • GPU
    MSI 3070 8GB Ventus 2x OC
  • Case
    LIAN LI LANCOOL MESH II Mesh RGB Black
  • Storage
    Kingston NV1 2TB M.2. NVMe
  • PSU
    Seasonic Focus GX 850w
  • Display(s)
    MSI OPTIX MAG 251RX IPS 240hz & ASUS MG248Q Vertical 144hz & Dell 60hz
  • Cooling
    NZXT Kraken x73 360mm
  • Keyboard
    Tt eSports Meka G1
  • Mouse
    Logitech G Pro Wireless
  • Operating System
    -Windows 10 Professional 64bit
https://linustechtips.com/topic/285637-low-mid-range-build/#findComment-3878067
Case: HAF 912
Thanks in advance
It's decent but what's your budget don't expect that much in bf4 but medium 60/70 fps should be doable.
It won't handle streaming that good. You might want to save up a little more and get an i5.
https://linustechtips.com/topic/285637-low-mid-range-build/#findComment-3878075
Actually it easily handle high.
Remember that BF4 is an amd title, mantle rocks! :P
50 fps avg on ultra.
Fx 6300 is not bad for streaming, I am pretty sure it's better than i5 at streaming.
But i5 is better at gaming (generally).
PC  Specs 2022:
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Tt eSports Meka G1
  • Mouse
  • Operating System
https://linustechtips.com/topic/285637-low-mid-range-build/#findComment-3878105
Budget : 50000 INR roughly equals to $800 but due to inflation assume $700
What website will you be ordering from? And do you also need windows, any peripherals, or a monitor?
PSU Tier List | CoC
https://linustechtips.com/topic/285637-low-mid-range-build/#findComment-3878119
Yes I know the gpu is fine had a 7850 myself which is even a bit slower but the cpu is going to bottleneck a little in bf4.
I5 destroys the fx-6300 in streaming and gaming.
https://linustechtips.com/topic/285637-low-mid-range-build/#findComment-3878135
It definitely doesn't "destroy" fx 6300 in streaming more cores is better than stronger cores when streaming.
In gaming it depends what i5 and what game.
And when you save ca 100$ that you can put into beefier gpu it is definitely not "destroyed".
Don't even bring up bottle-neck ..
People always exaggerate ..
I am not sure how it is in India but in Sweden i5's cost ca 127 bucks more.
PC  Specs 2022:
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Tt eSports Meka G1
  • Mouse
  • Operating System
https://linustechtips.com/topic/285637-low-mid-range-build/#findComment-3878158
The 6300 doesn't bottlneck a 270x? With a mild oc you can get it to handle a 290
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
https://linustechtips.com/topic/285637-low-mid-range-build/#findComment-3878178
Your ram is horribly mismatched, could be giving trouble. Just saying
That time I saved Linus' WiFi pass from appearing on YouTube:
A sudden Linus re-appears : http://linustechtips.com/main/topic/390793-important-dailymotion-account-still-active/
https://linustechtips.com/topic/285637-low-mid-range-build/#findComment-3878182
A haswell i5 will destroy an FX6300 in 99% of games (not when paired with a 270 though); and while an i5 does cost more, the better motherboard and cooler required for an FX6300 usually balances out that cost difference.
PSU Tier List | CoC
https://linustechtips.com/topic/285637-low-mid-range-build/#findComment-3878184
99% of games?
Now we are back to exaggerating ..
We are talking about 270x here, not intel vs amd.
Don't go all off topic.
Good luck fitting an i5 into his budget.
PC  Specs 2022:
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Tt eSports Meka G1
  • Mouse
  • Operating System
https://linustechtips.com/topic/285637-low-mid-range-build/#findComment-3878219
flipkart.com and amazon.in
I need a monitor but it is not included in that budget.
But i5 is quite a bit expensive if I get the haswell. @Iani100
Is this the icon for your currency "   " ?
Btw 50k India rupies is 789,99 bucks. So around 689,99 if it is ca 100 bucks more expensive total.
PC  Specs 2022:
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Tt eSports Meka G1
  • Mouse
  • Operating System
https://linustechtips.com/topic/285637-low-mid-range-build/#findComment-3878224
Yes Iknow
Had a similar setup before my intel platform and I'm a diehard bf4 player so I know what I'm talking about.
Also the fx-6300 is already outdated.
I know it will cost you a little more but it will be worth it in the long term.
And the 270x is good card and will play bf4 even at high with 70+ fps if combined with the right cpu.
https://linustechtips.com/topic/285637-low-mid-range-build/#findComment-3878231
PSU Tier List | CoC
https://linustechtips.com/topic/285637-low-mid-range-build/#findComment-3878264
Yes Iknow
8350 vs 4770k bf4.
This guy is also a diehard bf 4 and he says that barely noticed the gaming difference.
"The only place it really shows is the benchmark"'
PC  Specs 2022:
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Tt eSports Meka G1
  • Mouse
  • Operating System
https://linustechtips.com/topic/285637-low-mid-range-build/#findComment-3878267
Kind of going off topic guys. ₹ this is my currency and btw I am fine with going the intel route for a bit of future proofing.
Can you stretch your budget to 60k rupies?
There is 1 build ready by
djdwosk97
PC  Specs 2022:
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Tt eSports Meka G1
  • Mouse
  • Operating System
https://linustechtips.com/topic/285637-low-mid-range-build/#findComment-3878277
8350 vs 4770k bf4.
Don't be a damn fanboy
I've had an 1100t and a 8350 on a 990fx both performed like shit on amd my i5 750 beats the fx-6300 in bf4 yes that's righ a first gen i5.
I had a fps increase of about 20/40 fps on intel and more steady.
Please don't quote met with another bullshit video since I'm speaking with my own experience.
https://linustechtips.com/topic/285637-low-mid-range-build/#findComment-3878295
I am not a fan boy but I get slightly upset when other people talk shit about amd for no reason at all.
Your experience doesn't matter much since you have no benchmarks or proof to anyhting you say.
You get upset because I try to bring some sources in this (heated) argument?
PC  Specs 2022:
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Tt eSports Meka G1
  • Mouse
  • Operating System
https://linustechtips.com/topic/285637-low-mid-range-build/#findComment-3878322
Guys please stop Red vs Blue battle.
And btw can you suggest a MoBo with 4 Ram slots?
For an i5?
Perhaps this one https://pcpartpicker.com/part/asus-motherboard-z87a
PC  Specs 2022:
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Tt eSports Meka G1
  • Mouse
  • Operating System
https://linustechtips.com/topic/285637-low-mid-range-build/#findComment-3878329
I'm not a fanboy either.
I don't talk shit also benchmarks will reveal almost the same fps but when a game has issues and some small stuttering you can't see that in a benchmark.
I don't get upset, You can easily fit an i5 in this budget so why go for an amd.
Also the youtube video isn't a source since it doesn't mention any benchmarks and he could also be talking shit.......
But if you want to recommend outdated hardware that will need an upgrade in 2 years, fine I'm done.
https://linustechtips.com/topic/285637-low-mid-range-build/#findComment-3878341
