Hey there guys, I'm sure this isn't the best forum to be posting this, but I would just like some help on this. I just got pneumothorax a few days ago, and had a tube stuck inside me to remove the air. Now, my right lung which was half its normal size a few days back, is now at 90% its normal size. However, I did not do enough to expand the lung so all the air would be removed. Can you guys suggest the best ways to expand it as fast as possible? If I can't do it by this saturday, I will have to have a minor operation. I would like to avoid this if possible, and only by expanding the lung enough I can avoid it. Please guys?
https://linustechtips.com/topic/285328-pneumothorax-help/
what ?
https://linustechtips.com/topic/285328-pneumothorax-help/#findComment-3873878
i found this, no idea if any of it would help http://www.findhomeremedy.com/top-home-remedies-for-pneumothorax/
Good luck!
// irenebb-pc v5 // [] Intel i5-9400F [] Radeon VII Lisa Su Edition [] 24GB Crucial Ballistix [] Acer ED323QUR (1440p/144hz) []
https://linustechtips.com/topic/285328-pneumothorax-help/#findComment-3873919
I would not be asking for medical advice on here.... A good majority of us are under the ago of 20, and there are more engineers than med students on here.
Corsair 400C- Intel i7 6700- Gigabyte Gaming 6- GTX 1080 Founders Ed. - Intel 530 120GB + 2xWD 1TB + Adata 610 256GB- 16GB 2400MHz G.Skill- Evga G2 650 PSU- Corsair H110- ASUS PB278Q- Dell u2412m- Logitech G710+ - Logitech g700 - Sennheiser PC350 SE/598se
Is it just me or is Grammar slowly becoming extinct on LTT?
https://linustechtips.com/topic/285328-pneumothorax-help/#findComment-3873930
I have had 2 of these, the first one happened a few months ago and was bad, i had to have the chest drain put in for 5 days before they finally let me leave.. I waited a few days before going to the doctors and if i waited any longer my lung could have collapsed. A few weeks after i had another one but it was not as big and i didn't have to have the drain in again. I am not sure there is anything you can do to speed up the process and you should probably ask your doctor rather than posting on here. How did yours happen anyway? i got both of mine from being tall and thin.
p.s If i get another one i will have to have an operation too to stop them from happening which i am not fond of.
I also can't go on holiday for a year or go scuba diving ever.
https://linustechtips.com/topic/285328-pneumothorax-help/#findComment-3873939
Mine was due to being tall and thin too, dang it sucks! Can you go on roller coasters? Just asking as I may(or may not) be going to a theme park.
https://linustechtips.com/topic/285328-pneumothorax-help/#findComment-3874060
Should be able to.. When i was disharged they didnt say anythng about rollercoasters, just planes and scuba diving. Although i wouldnt do anything like going on rollercoasters or a lot of sport for a few weeks, my doctor told me it can take months for it to fully heal because they had to cut through so much tissue to get the tube in.
https://linustechtips.com/topic/285328-pneumothorax-help/#findComment-3874107
Dang alright. I have to fly in a months time anyhow, because uni in Australia will be starting for me...
https://linustechtips.com/topic/285328-pneumothorax-help/#findComment-3874440
