http://pcpartpicker.com/p/ZxgGt6
That is my build i want to custom water cool two r9 295x2 x2 and my cpu
Im confused to which parts to get on frozencpu
The only thing i know is that i want to have red coolant and clear tubing and i cant find compability on the website i know the parts but confused with the fittings for it
If you could help me get a part list my max budget is 1000
https://linustechtips.com/topic/284391-i-need-help-picking-parts/
Is this your current build or have you not bought the parts yet?
CPU: Intel Core i7 4770 | Motherboard: Asus Z97-A | RAM: 8gb (2x4gb) Corsair LP @1600mhz | GPU: Asus TUF GTX 1660 OC 6GB | Case: Fractal Design Define R4 | Storage: 250gb Samsung 840 EVO and 1TB WD Black 7200rpm | PSU: Corsair CX750M | Display: Asus VG245H 1920x1080 | Cooling: Cooler Master Hyper 212 EVO and default case fans | Laptop: Early 2015 13" Macbook Pro Retina - i5 2.7Ghz - 256GB SSD
