I'm planning to get a R9 280, but the power consumption is so brutal. I think it's unnecessary for R9 280 to operate at 100% for an online game like Dota 2. (Because even 260x could push the FPS over 120)
As V-sync limits the FPS to 60, so will it saves the GPU workload and power?
P.S. Nvidia v-sync and AMD v-sync, are they same? which one is better? or save more power?
thx
Primary PC
CPU: AMD Ryzen 7 5700X3D | GPU: Zotac RTX 3080Ti 12GB | M/B: Asus ROG Strix X370-F | RAM: Corsair Pro SL 3200MHz 32GB | SSD: WD Black SN7100 1TB / Samsung 870 Evo 1TB | HDD: Seagate EXOS X16 16TB x2 | Power: Corsair RM850e | Sound card: Creative Sound BlasterX AE-5  | Case: NZXT H500 | Cooling: NZXT Kraken X62 | Display: Samsung QLED 27" 2K 144Hz VR: Pico 4
Secondary PC
CPU: AMD Ryzen 5 5600 | GPU: Asus RTX 4060 8GB | M/B: Asrock B450M Pro 4 | RAM: HyperX Fury 3200MHz 32GB | SSD: Crucial P1 1TB | HDD: WD Black 1TB | Power: Coolermaster Masterwatt 550 | CaseAerocool Cylon Mini | Cooling: BeQuiet Pure Rock Slim 2 | Display: Samsung QLED 24" FHD 144Hz VR: Meta Quest 2
Thanks for reading
https://linustechtips.com/topic/284268-does-v-sync-save-power-s/
vsync might save power if you get more fps than your refresh rate and vsync is universal for amd and nvidia.
https://linustechtips.com/topic/284268-does-v-sync-save-power-s/#findComment-3858168
V-sync like any fps limiter can help the graphic card work less hard when it needs to and save power.
This belongs in the Graphics Cards section. I'm moving the thread.
https://linustechtips.com/topic/284268-does-v-sync-save-power-s/#findComment-3858172
I think Nvidia has an adaptive V-sync thing :S
Primary PC
Secondary PC
Thanks for reading
https://linustechtips.com/topic/284268-does-v-sync-save-power-s/#findComment-3858178
ops. i thought that's for hardware only
Primary PC
Secondary PC
Thanks for reading
https://linustechtips.com/topic/284268-does-v-sync-save-power-s/#findComment-3858184
thx
V-sync will save power as the GPU is only pushing out frames to sync up with the monitors refresh. Its not an FPS limiter per say, as V-sync is not actually trying to push out a set number of frames per second.
An FPS limiter like RTSS just limits how many frames are sent to the monitor per second, but the GPU is still pushing as many as it can. It will not save power.
If you are recording with something like fraps or dxtory, than they can lock framerates rendered by the GPU itself, and save power.
R9 3900XT | Tomahawk B550 | Ventus OC RTX 3090 | Photon 1050W | 32GB DDR4 | TUF GT501 Case | Vizio 4K 50'' HDR
https://linustechtips.com/topic/284268-does-v-sync-save-power-s/#findComment-3858246
adaptive vsync is different than vsync it wont be power efficient as regular vsync.
https://linustechtips.com/topic/284268-does-v-sync-save-power-s/#findComment-3858249
Adaptive vsync is simply regular vsync that can switch itself off when it goes below the refresh rate. G-sync would limit fps to max refresh rate so I guess it could save power.
https://linustechtips.com/topic/284268-does-v-sync-save-power-s/#findComment-3858293
thx
What you mean by brutal? It's not really that high.
But why GPU usage is lower when FPS limiter is used?
https://linustechtips.com/topic/284268-does-v-sync-save-power-s/#findComment-3858613
Even though it's a re-brand HD7950, but it comes with 250W TDP. That's why I want to know if there is a way to limit the power consumption. Electricity rate in Australia is pretty expensive.
Primary PC
Secondary PC
Thanks for reading
https://linustechtips.com/topic/284268-does-v-sync-save-power-s/#findComment-3864743
